Warning message
Wireless with Cisco ACS
Oct 11th, 2013
I have a wireless solution and want to add a CISCO ACS 5.3, but unfortunately I do not have an LDAP, then the users are local to the Cisco ACS.
Not as a certifying entity, either I have a domain on my network.
I just want to use the CISCO ACS to enable users and sign me to the wireless network only with my username and password enabled on the Cisco ACS.
Someone knows a configuration or anyone know if you can do with this version of Cisco ACS.
thanks
Richard Atkin Fri, 10/11/2013 - 09:10
  • Silver, 250 points or more
So you want to authenticate people to a Wireless network, but only by using ACS, without any AD/LDAP integration?
This is perfectly doable with a PEAP or EAP-FAST (or LEAP, lol) setup.
julio.vergara Fri, 10/11/2013 - 10:55
This only works when I change the settings in WINDOWS clients.
Is there any way without changing the client and automatically WINDOWS only ask you username and password.
craig.beck Fri, 10/11/2013 - 15:31
If you don't have an AD to automatically configure the Windows clients there's no way to do it without manually configuring them, unless you install a trusted 3rd-party cert on the ACS for EAP authentication. This might still require manual config on the client though if certificate validation doesn't work.
Related Content
Trending Topics - Security & Network
