Warning message
ASA FIREWALL ISSUE
Oct 11th, 2013
My setup is like this:
ASA-5505-SITE-A (1.1.1.1)
ASA-5510-SITE-B (1.1.2.1)
On this side the ASA inside interface gooing into a router as WAN.
My LAN outside my routeur is 192.168.1.x
There is a VPN UP between SITE-A and SITE-B
From SITE-B I can ping everything to SITE-A
From SITE-A to SITE-B, nothing works.
Please help me.
Jouni Forss Fri, 10/11/2013 - 09:13
I am not sure I understand the setup from the above.
If you could share the configurations of the ASA firewalls (without public IP addresses etc.) then could look through the configurations.
- Jouni
pl.mailloux Fri, 10/11/2013 - 09:39
On SITE-A my PC's IP adress come directly from the ASA 1.1.1.x
On SITE-B we use a router behind the firewall so my PC's adress are : 192.168.1.x
I can ping from SITE-B to SITE-A without any problem.
I cannot ping from SITE-A to SITE-B.
There is my 2 firewalls config.
SITE-A
Result of the command: "show run"
: Saved
ASA Version 9.1(3)
hostname ciscoasa
enable password *** encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd *** encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 1.1.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address SITE-A-PUBLIC-IP 255.255.255.240
boot system disk0:/asa913-k8.bin
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network LAN-SITE-B
subnet 1.1.2.0 255.255.255.0
object network LAN-SITE-A
subnet 1.1.1.0 255.255.255.0
object network Firewall-SITE-B
host SITE-B-PUBLIC-IP
object network SERVER01
host 1.1.1.2
object-group service ALL-IP tcp-udp
description ALL-IP
port-object range 1 65535
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside_cryptomap extended permit ip object LAN-SITE-A object LAN-SITE-B
access-list OUTSIDE-IN extended permit ip any object SERVER01
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static LAN-SITE-A LAN-SITE-A destination static LAN-SITE-B LAN-SITE-B no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
nat (inside,outside) static SERVER01-PUBLIC-IP
access-group OUTSIDE-IN in interface outside
route outside 0.0.0.0 0.0.0.0 SITE-A-PUBLIC-GATEWAY 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no user-identity enable
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 1.1.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer SITE-B-PUBLIC-IP
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 1.1.1.100-1.1.1.125 inside
dhcpd dns 24.200.241.37 24.201.245.77 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy GroupPolicy_SITE-B-PUBLIC-IP internal
group-policy GroupPolicy_SITE-B-PUBLIC-IP attributes
vpn-tunnel-protocol ikev1 ikev2
username *** password *** encrypted privilege 15
tunnel-group SITE-B-PUBLIC-IP type ipsec-l2l
tunnel-group SITE-B-PUBLIC-IP general-attributes
default-group-policy GroupPolicy_SITE-B-PUBLIC-IP
tunnel-group SITE-B-PUBLIC-IP ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect sip
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:8306344f5f134526aa6df7293730742f
: end
SITE-B
: Saved
ASA Version 9.1(3)
hostname ciscoasa
names
nameif outside
security-level 0
ip address dhcp setroute
nameif inside
security-level 100
ip address 1.1.2.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ftp mode passive
object network FireWall-SITE-A
host 1.1.1.1
access-list outside_cryptomap extended permit ip object LAN-SITE-B object LAN-SITE-A
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu management 1500
arp timeout 14400
nat (inside,outside) source static LAN-SITE-B LAN-SITE-B destination static LAN-SITE-A LAN-SITE-A no-proxy-arp route-lookup
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto map outside_map 1 set peer SITE-A-PUBLIC-IP
crypto map outside_map 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd address 1.1.2.100-1.1.2.125 inside
dhcpd dns 142.169.1.16 199.84.242.22 interface inside
dhcpd enable inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
group-policy GroupPolicy_SITE-A-PUBLIC-IP internal
group-policy GroupPolicy_SITE-A-PUBLIC-IP attributes
tunnel-group SITE-A-PUBLIC-IP type ipsec-l2l
tunnel-group SITE-A-PUBLIC-IP general-attributes
default-group-policy GroupPolicy_SITE-A-PUBLIC-IP
tunnel-group SITE-A-PUBLIC-IP ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:db8f53008f268da84e76bae3bb414bc3
: end
Jouni Forss Fri, 10/11/2013 - 10:13
Some observations,
  • You say that Site B has a router behind the LAN interface of the ASA
  • You say that Site B can ping Site A with no problem
  • You say that Site A cant ping Site B
  • On Site B there is no Route for the network 192.168.1.0/24
  • On Site B you have a Management interface which has the address range 192.168.1.0/24 also?
So I am beginning to think that the router behind the Site B ASA is doing Dynamic PAT for the network 192.168.1.0/24 behind it. This would mean that all traffic from the 192.168.1.0/24 would be PATed to some IP address from network 1.1.2.0/24. This again would enable traffic to flow from Site B to Site A normally. Considering the Dynamic PAT done by the Site B LAN router would mean though that no connection initiation would work from Site A to Site B since you cant form connections through Dynamic PAT from the external side.
So my guess would be that you would have to
  • Remove the Site B management interface configurations, atleast the IP address. If its in use change the network for the Management interface
  • Disable any type of NAT on the LAN Router at Site B so Site A can actually see the local network 192.168.1.0/24
  • Change the VPN and NAT configurations on the ASAs to reflect this change in the Site B network
The above would most likely affect your Site B Static NAT configuration you did just in the other discussion here on the forums.
One other alternative is that you configure Static NAT for the hosts you need on the Site B router from 192.168.0.x to 1.1.2.x so they can be connected from Site A
Hope I made sense
- Jouni
