Warning message
pptp through to vpn server being denied by Cisco ASA 5505
I am assuming I am missing something slight.  I have my pptp access rule allowing outside inside on pptp --  I also have a nat rule that says pptp traffic should be directed  to server 10.1.10.11 (VPN Server) ...  Yet my VPN connection is getting  denied.  Windows trouble shooter says the host is replying that it's  alive, but is denying the connection.  Any ideas based on my config?   This is a Cisco ASA 5505 v8.2
Result of the command: "show run"
: Saved
ASA Version 8.2(5)
hostname DTS-ASA
enable xxxxxxxxxx
passwd xxxxxxxxxx
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.1.10.100 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 74.xx.xx.225 255.255.255.248
ftp mode passive
object-group network DM_INLINE_NETWORK_1
network-object 10.xx.xx.0 255.255.255.0
access-list outside_access_in extended permit tcp any interface outside eq pptp
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit gre any interface outside
access-list outside_1_cryptomap extended permit ip 10.1.10.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip 10.1.10.0 255.255.255.0 10.xx.xx.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.1.10.0 255.255.255.0
static (inside,outside) tcp interface pptp 10.1.10.11 pptp netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 74.xx.xx.230 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.1.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group5
crypto map outside_map 1 set peer 63.xx.xx.242
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 170
encryption 3des
hash sha
group 5
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 75.xx.xx.75 75.xx.xx.76
dhcpd auto_config outside
dhcpd address 10.1.10.104-10.1.10.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group 63.xx.xx.242 type ipsec-l2l
tunnel-group 63.xx.xx.242 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect pptp
  inspect icmp
service-policy global_policy global
: end
<br/>
<br/>
I have also included a few ASDM screen shots if it helps..  Any help appreciated!!
Mike Williams Fri, 10/11/2013 - 18:30
  • Bronze, 100 points or more
You need to allow GRE (IP protocol 47) as well. Unfortunately you can't port-forward GRE, so your PPTP server needs a dedicated IP for a 1-to-1 NAT.
Mike
Sent from Cisco Technical Support Android App
Mike,
To be honest I am pretty new to this.  I had the VPN working, until I changed the IP of the server to outside the DHCP scope so it would remain static.  Only after that change, I deleted the PPTP server object, added a new pptp server object, and pointed the rules that used the old object to the new object.
That being said, according to my config I am allowing GRE correct?
If you look at my config what exactly needs to change to get this fixed?
