Small Business Support Community
Explore what Cisco has to offer for your small business IT needs. Learn from your peers and Cisco experts.
Browse the Community
Routers - Small Business
Routers tailored for small businesses, providing efficient and reliable connectivity for your growin...
Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small busi...
Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost product...
Cisco Business Dashboard
Stay on top of your business performance with the Cisco Business Dashboard, providing real-time data...
Activity in Small Business Support Community
CBS350 Setup guidance
Hello,I have an ISP router/modem, along with assignable public IP addresses for use. Leaving default VLAN1 alone (mgmt), I created VLAN10 (192.168.0.0/24) and VLAN20 (172.16.3.0/24) on the CBS350.ISP router "internal" ip 172.16.2.1/24On CBS350 port G...
Limited internet Connection
Hi, I have Mikrotik Cloud base router its connect with cbs 100 switch (WAN) and its connect with cbs350(LAN). I am getting this error. Kindly this one is from swx side or WAN side and what's the solution. Thanks @
8MFT-T1/E1
how to activate the module on cisco 4400 router for E1 connections.#card type e1 0 4 showing error, card not found or command wrong
CBS350-24p-4x not possible to use all TE Ports
Hey GuysFor a Lab device I've got a cbs350-24p-4x. With it's 4 TenGigabitEthernet ports I'd like to use port TE1/0/1-2 for lacp to my firewall and with TE1/0/3-4 ports I'd like to connect to my vsphere ESXI host.The Switch is running on the latest FW...
joel157 by Level 1
  • 82 Views
  • 1 replies
Editing My Phone APPS
I enabled SNR on a users line.  Works fine.Customer does not like that other phones show the option under CME Services URL>My Phone APPS> Single Number Reach, even when the phone line is not programmed to allow SNR.  Is the SNR option something that ...
tknapp by Level 1
  • 1338 Views
  • 11 replies
Resolved! FTD intervlan questioning,
Scenario,Host-A(10.10.30.3/24) connects to access port on SwitchA with various other vlans also configured via access ports. SwitchA connects on a Trunk port to a CatSwitch. Firepower inside ½ interface trunks to CatSwitch. On The CatSwitch 3 vlans; ...
GatLMCO by Level 1
  • 297 Views
  • 12 replies
CMS SMART LICENSE ERROR
H, i have this msg error in CMM logs  " django.db.utils.IntegrityError: duplicate key value violates unique constraint "cmm_licensing_hostlicens_cluster_id_host_timestam_3e015b7f_uniq"Apr 17 08:20:09 cmm cmm-web_worker_1[275]: DETAIL: Key (cluster_id...
CBD 2.7.1 Error while using a wildcard certificate
I'm running CBD2.7.1 and installed a public wildcard certificate.The following error is flashing on the top of the dashboard:"Server certificate does not contain your server address in Subject Alternative Name."Is this a bug when using wildcard certs...
SteveKC by Level 1
  • 119 Views
  • 3 replies
