Warning message
Translation Pattern for Diverted calls
Oct 14th, 2013
Hi)
I'm after a bit of help with translation patterns.
We have an incomming BRI line on an H323 gateway, 5056020, that follows a translation rule
"rule 1 /^.*\(..\)/ /4581\1/" to connect to reception (it replaces 5056020 with 458120
which is the recption phone.
We have a separate PSTN line, 5056030, that is redirected by the telco to 5056020.
I need to be able to send these incomming redirected call to a different extn, 458162.
I have tried a few options such as
voice translation-rule 1       **sends calls to reception**
voice translation-rule 7    ** sends calls to Extn 458162**
rule 1 /^5056030$/ /458162/
voice translation-profile INGRESS
translate called 1
translate redirect-called 7
Whatever I do all calls go to reception, any thoughts ?
Below is debug isdn q931 for reference for a redirected call.
I am trying to work with the "redirecting num 5056030" part.
thanks.
router#
Oct 14 13:47:58 UTC: ISDN BR0/2/1 Q931: RX <- FACILITY pd = 8  callref = N/A
        Facility i = 0x91A10E02010102010C30060A01010A0101
                Protocol Profile = Remote Operations Protocol
                0xA10E02010102010C30060A01010A0101
                Component = Invoke component, Unsupported operation
        Called Party Number i = 0x81, '5056030'
                Plan:ISDN, Type:Unknown
Oct 14 13:47:58 UTC: ISDN BR0/2/1 **ERROR**: host_facility_invoke: HOST_FAC_INV: B-channel = D-channel
                call id 0xFFFF
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8  callref = 0x1E
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Facility i = 0x91A1210202008002010F30180201010A0101A110A00EA10C0A0104120734383633303330
                0xA1210202008002010F30180201010A0101A110A00EA10C0A0104120734383633303330
                        Invoke Id = 128
                        Operation = Diversion Leg2
        Calling Party Number i = 0x0180, '01234 5678910'
router# i = 0x0183, '01234 5678910'
        Called Party Number i = 0x81, '5056020'
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: extract_redirect_orig_called_ie: IE type redirecting num 5056030
                 reason 15 cnt 1 plan 4 type 1 pres 0
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x9E
        Channel ID i = 0x89
                Exclusive, B1
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8  callref = 0x9E
router#
router#
Oct 14 13:48:06 UTC: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x1E
        Cause i = 0x8090 - Normal call clearing
translate called 1
Nishant Savalia Mon, 10/14/2013 - 07:40
  • Silver, 250 points or more
Hi Rob,
Can you please share below things:
1). running-config
2). debug isdn q931
3). debug voice ccapi ind 2
4). debug voice translation
After that, try by modifying your voice translation-rule 1 as below
rule 1 /^.*\(20$\)/ /4581\1/
OR
rule 1 /^50560\(20$\)/ /4581\1/
OR
rule 1 /^5056020$\/ /458120/
Nishant Savalia
kidcisco212 Tue, 10/15/2013 - 02:00
Hi Nishant,
Thanks for the reply but I am not sure how this will help, the translation rules provided surely will only affect calls to  5056020 which already works.
What I am trying to do is pick out the diverted number of 5056030 which can be seen in the above q931 debug at
"Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: extract_redirect_orig_called_ie: IE type redirecting num 5056030"
which I need to send to extn 458162.
Sorry I am not at work for the other info at the moment
Regards, Rob
Ayodeji Okanlawon Tue, 10/15/2013 - 03:04
  • Cisco Designated VIP,
    2017 IP Telephony
Rob,
Have you tried just using "translated called" instead of redirect. You need to change your translation rule to include the number...
e.g.
rule 2 /^5056030$/ /458162/
