Warning message
SG300 ssh strange error: "A client is already connected"
Oct 14th, 2013
I've got a few SG300-52 small business switches running software version 1.3.0.62 which I configured for ssh management access with public key authentication via:
ip ssh server
ip ssh pubkey-auth auto-login
username mgmt password ... privilege 15
crypto key pubkey-chain ssh
user-key mgmt rsa
key-string ...
This is working fine if I connect interactively from my management system with:
ssh -i mgmt_id_rsa [email protected]
where mgmt_id_rsa is the name of a file containing the private key.
I get a privileged command prompt as intended, without being asked for a password.
However if I try to pass a command on the ssh command line like this:
ssh -i mgmt_id_rsa [email protected] show version
the command just hangs until I hit the Enter key a second time, and then emits the strange message:
Received disconnect from 10.11.12.13: 2:
(Exactly like that, including the line break after the "2:" and the blank before "A client".)
This is unfortunate as the objective is to send commands to the switch from a script.
The same happens if I pipe the command I want to send into ssh like this:
echo show version | ssh -i mgmt_id_rsa [email protected]
except the error message appears immediately and I don't have to hit Enter a second time.
Looks like I hit another bug in Cisco's ssh implementation? Any idea for a workaround?
Tilman
Tilman Schmidt Tue, 10/15/2013 - 01:29
A few more data points:
ssh -t -i mgmt_id_rsa [email protected] show version
(force pseudo-tty allocation) echos the "show version" command but does not execute it. The session then doesn't respond to any keyboard input except "~." to close the connection.
ssh -n -i mgmt_id_rsa [email protected] show version
echo show version | ssh -n -i mgmt_id_rsa [email protected]
(prevent reading from stdin) both hang until I hit ctrl/C to abort.
Trying to add the -t option to either -n or the pipe variant results in the message: "Pseudo-terminal will not be allocated because stdin is not a terminal."
SSH debug output (ssh -vvv ...) only shows the command being sent to the SG300 and no reply ever coming back.
Joshua Hoke Mon, 05/11/2015 - 13:26
I was able to duplicate this behavior on multiple switches running firmware version 1.4.1.3
Were you ever able to find a solution?
Related Content
