Warning message
cisco asa 5520 version8.4(2) ---static PAT unreachable,why
Oct 16th, 2013
I config static pat at asa 5520 but static pat unreachable ,why?
ciscoasa# show run
: Saved
ASA Version 8.4(2)
interface GigabitEthernet0
nameif Inside
security-level 100
ip address 12.1.1.2 255.255.255.0
interface GigabitEthernet1
nameif Outside
security-level 0
ip address 23.1.1.2 255.255.255.0
object network static-pat-inside
host 12.1.1.1
object service static-pat-inside-service
service tcp destination eq telnet
object service static-pat-outside-service
service tcp destination eq 2323
access-list telnet extended permit tcp any object static-pat-inside eq telnet
nat (Inside,Outside) source static static-pat-inside interface service static-pat-inside-service static-pat-outside-service
access-group telnet in interface Outside
now,i use 23.1.1.1 telnet 23.1.1.2 2323,  but  unreachable ,why?
CSCO11932132 Thu, 10/17/2013 - 18:18
now i config it by this:
object network inside-network
nat (Inside,Outside) static outside-network service tcp telnet 2323
ciscoasa# config terminal
ciscoasa(config)# nat (Inside,Outside) ?
configure mode commands/options:
  <1-2147483647>  Position of NAT rule within before auto section
  after-auto      Insert NAT rule after auto section
  source          Source NAT parameters
it success reachable! but after nat (Inside,Outside) desn't have static!!!
