Warning message
Two VWIC3-2MFT's won't wake up in a 2921 router
Answered Question
Oct 16th, 2013
My Cisco 2921 came shipped with two preinstalled VWIC3-2MFT-T1/E1, and I had no problems adding it as MGCP gateway to my new CUCM BE6000 version 9.1. However, even though both VWIC3's appear nicely at show inventory, they seem completely dead. All LED's are dark, even when looping Tx-Rx.
show version gives "(C2900-UNIVERSALK9-M), Version 15.2(4)M3", which I think is sufficient for VWIC3. However, this is the situation right now:
show isdn status returns "Invalid input detected at..."
show controllers E1 returns no output at all
show mgcp endpoint returns no output at all
Any experts out there?
Correct Answer by George Thomas about 3 years 10 months ago
Do you have the card type t1 x y command?
Please rate useful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
George Thomas Wed, 10/16/2013 - 15:07
  • Blue, 1500 points or more
MortenBjor Wed, 10/16/2013 - 23:15
Thanks George, that helped. VWIC's came up with LEDs, but still no ISDN related commands seems to be valid. I've tried
show isdn status
debug isdn q931
Service Engine is in shutdown status. I didn't think that could have anything to do with this, but now I'm beginning to run out of ideas.
islam.kamal Wed, 10/16/2013 - 23:29
  • Red, 2250 points or more
please find the below:-
card type T1 0 0
network-clock-particpate wic 0
network-clock-select T1 0/0/0
isdn switch-type primary-ni
controller T1 0/0/0
no shu
pri-group time-slots 1-24 service mgcp
interface s0/0/0:23
isdn bind-l3 ccm-manager
isdn incoming-voice voice
isdn negotiate-bchan
isdn outgoing ie display
isdn outgoing ie redirecting-number
Then do show isdn status. If you find  on the show any problems  problems , please do as the below
interface s0/0/0:23
no isdn bind-l3 ccm-manager
on show isdn status , you have to find the below
layer 1 activated
layer 2 MULTIPLE_FRAME_ESTABLISHED
Thank you
please rate all useful information
Aman Soi Thu, 10/17/2013 - 00:26
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Morten,
can u post the show version/show run/ show isdn status/show controllers E1/show diag and show inventory output from Router?
regds,
aman
MortenBjor Thu, 10/17/2013 - 01:34
Problem solved !
George Thomas helped med bringing up the VWI3's, (see post above).
But the lack of ISDN commands was due to a missing license accept. After accepting EULA and a reboot, all cannels came up, and commands show isdn status and debug isdn q931 vere valid.
Thanks to everyone!
Related Content
