Warning message
the FWSM 6509,whether souport PBR
Answered Question
Oct 16th, 2013
HI
the FWSM 6509,whether souport PBR ?
Correct Answer by Carlo Poggiarelli about 3 years 10 months ago
Hi.
As I know PBR is not supported on FWSM but if you need you can do it on 6509 at SVI level.
Carlo
Overall Rating: 5 (1 ratings)
Correct Answer
Carlo Poggiarelli Wed, 10/16/2013 - 23:03
  • Green, 3000 points or more
Hi.
Carlo
vvvnnnzzz Mon, 08/04/2014 - 23:25
Hello ,
Did you eventually run the PBR on the 6509 SVI between the 6509 and the FWSM ?
I am having problem with the PBR applied to the SVI , it doesnt seems to capture any traffic .
Valentin
Related Content
