Warning message
7201 auxilery problem
Oct 15th, 2013
hi all,
i am using cisco 7201 as edge router, and i am trying to connect via auxeliry to other cisco device console.
the connection is done with rollover cable.
the commad is "telnet 1.1.1.1 6001" ( 1.1.1.1 is loopback address).
after i typed the command, it seems that the window is stuck.
in other words: i can't reace the othe device.
does anyone ever encounterd the problem?
thanks jacob
