fractional E1 / External CSU - CISCO2921
richard-ziga
Does anyone have any information as to what type of VWIC/HWIC is required for this type of environment?  The external CSU is such old technology that it is difficult to find any information regarding this type of setup for a 2921 router.
Rich
11 Replies 11
Steve Fry
Hello Rich,
Take a look at this:
HWIC-1CE1T1-PRI
Thanks for the reply Steve.  The problem is that the customer requires that an external CSU is used.  The card you suggested is a CSU.
thanks,
Rich
All right, I misunderstood. We have used several different models of Adtran csu/dsu. Take a look at the 120 Lite. They are faily easy to configure.
Steve, do you know what type of VWIC/HWIC is required for the external E1 CSU?
Rich
I ahd to look it up because it has been so long since I configured an external CSU. Look at HWIC-2A/S. Confirm that it will work with your IOS.
Yeah, this is the card that was suggested by someone else, but I can't find any docs on configuration, neither can the TAC.
paolo bevilacqua
All E1 interfaces support fractional E1. eg VWIC2.
Thanks for your response Paolo, the problem is I must connect to an external CSU - V.35
CAB-SS-V35MT is the cable I will have to use, probably
Then use hwic-1t.
I don't believe this card works with E1, do you know?
Rich
The connection type limits your choice of WAN cards, so if you have to use a v.35 cable then you can only use a hiwc-1t or hwic-2t
