Clock in Logs
Answered Question
Oct 17th, 2013
Hello Friends - I am seeking your help in understanding why the timestamp shown in Logs differ from Router Clock set thru NTP. Here is my observation
Note: both the routers are SYNC with NTP server at Strarum 3
Router-1 Configuration
service timestamps log datetime msec localtime
     here log messages (show log output) matches with Clock (show clock)
Router-2 Configuration
     here log messages (show log output) doesn't matches with Clock (show clock). There is some difference of +3hrs 20 minutes (additional in Log message timestamp)
May i know from where the logs assumes the time in Router-2 ? I am not seeing this time in NTP
Thanks in advance
SAIRAM
Correct Answer by Vasilii Mikhail... about 3 years 10 months ago
Hello.
If you enter "service timestamps log datetime localtime", then you see local time (that is CDT).
If you omit "localtime", then time is shown for UTC (5 hours later than CDT); so the event happend at 15:44:31 UTC = 10:44:31 CDT.
PS: for multinational companies it's a best practice to keep routers' clock in UTC (and timestamps as well).
Overall Rating: 5 (1 ratings)
snarayanaraju Thu, 10/17/2013 - 10:19
Friends - To add more to get more visibility here is the output
Router-2
rtr2# show clock
12:17:16.860 CDT Thu Oct 17 2013
rtr2#show ntp assoc
  address         ref clock       st   when   poll reach  delay  offset   disp
*~165.130.1.7     65.49.70.244     3    347   1024   377 27.565 -10.826 14.835
rtr2-st0564# show log | in Oct 17
033016: Oct 17 15:44:31.420: %IPPHONE-6-UNREGISTER_ABNORMAL
Correct Answer
Vasilii Mikhail... Thu, 10/17/2013 - 10:55
  • Gold, 750 points or more
Hello.
snarayanaraju Thu, 10/17/2013 - 11:06
Thank you Mikhailovsky - Sounds logic. Here is the observation
rtr1#show clock
13:04:36.973 CDT Thu Oct 17 2013
rtr1#show log | in Oct 17
502468: Oct 17 18:03:46.133: %SEC-6-IPACCESSLOGP:
Excellent.. Thanks again
SAIRAM
