How to Stop WLC upgrade TFTP transfer
michal.paulus
Hi all,
I would like to ask you if there is any option how to stop TFTP transfer for WLC upgrade???
Thanks for your inputs.
Michal
Abha Jha
reboot the box via power cycle
Uplink port shutdown on SW did the same trick.
I wanted to know if there exists sort of "transfer download stop" or something similar
Not applicable
Issue - "transfer in progress by another user"
Had this problem and file transfer was in progress for long hours with no options permitted.
"RESET SYSTEM FORCED" helped to reset and recovered from the tftp transfer that was for long hours.
ralbertos21
The least disruptive way to stop a WLC TFTP Transfer is to kill the service on the machine side (i.e. Windows Server running TFTP client).
Also, using FTP is a faster and more effective way of transferring images.
