Warning message
Layer 3 Switch functionality
Answered Question
Oct 17th, 2013
Hi all, I have a Cisco 3560x-24 switch that I use as the core at one of my offices. Until now I didn't need any routing protocols on this switch and had a bunch of static routes. However now due to some requirements, this switch must advertise it's static routes via EIGRP to an adjacent router who then in turn advertises them onto others. This route advertisement works perfectly. All my other routers (approx. 70) can see the static (external) routes advertised by the core switch.
Below is a sh ver and sh license from the switch. It seems, from the output below, switch is running ipbase license. Could this cause any issues with traffic flow? Reason I am asking is that at some of my offices, I have intermittent issues while connecting to destinations whose static route is being advertised by this switch. Routing stays fine, as the routers at all other offices know about the destination however they intermittently loose connectivity.
Please advise
SW-0076#sh ver
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 15.0(1)SE1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 01-Dec-11 14:16 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
SW-0076 uptime is 1 year, 45 weeks, 22 hours, 2 minutes
System restarted at 03:08:19 UTC Wed Dec 7 2011
System image file is "flash:/c3560e-universalk9-mz.150-1.SE1/c3560e-universalk9-mz.150-1.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1542K089
Last reset from power-on
8 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 64:9E:F3:2E:32:00
Motherboard assembly number     : 73-12554-05
Motherboard serial number       : FDO15421Y9W
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : 800-32786-01
Daughterboard serial number     : FDO153904KJ
System serial number            : FDO1542K089
Top Assembly Part Number        : 800-31331-02
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COMJU00ARB
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       15.0(1)SE1            C3560E-UNIVERSALK9-M
Configuration register is 0xF
SW-0076#sh license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: Life time
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: lanbase
        Period left: 0  minute  0  second
Correct Answer by Reza Sharifi about 3 years 10 months ago
The licensing has nothing to do with the switch having intermittent issues while connecting to other destinations.
Your license is IP based.  Usually, with IP Base license level you can run static router and EIGRP.  If you need OSPF, BGP etc.... you would  need IP Services license. You need to look at your at other area of your network to figure out what caused the issue.
Have a look at table-2 in this link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-579326_ps10745_Products_White_Paper.html
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Thu, 10/17/2013 - 17:58
  • Cisco Designated VIP,
    2017 LAN
Ricky S Thu, 10/17/2013 - 18:06
Thank you for the clarification. Much appreciated.
s.lachica Thu, 10/17/2013 - 19:42
Hi Ricky,
Reza Sharifi is correct. This could not, in anyway be related to your license.
If you would like to troubleshoot the intermittent issues however, you can check the path on where packets are going from source to the static routes that you have.
A good start would be to ping from that switch going to the static route destinations, check the interfaces (show int) for any input/output/crc errors, etc). show log and show proc cpu history are also useful commands for checking hardware and resource capacity related issues.
Hope this helps.
