Warning message
restore SP from XML backup - best practise?
Oct 18th, 2013
i have a (logical, so xml) backup from a UCS cluster. Someone accidentialy deleted a service profile. I know i can import the logical config but other things have changed and i want to just import the missing service profile.
I could edit the XML file (yuk), delete all other stuff and import.
i also tried to create individual backups of objects by clicking "Copy XML" and saving the result but UCSM does NOT accept that file for import.
Is there any other, better way to achive this?
Michael
Robert Burns Fri, 10/18/2013 - 06:29
  • Cisco Employee,
Michael,
Restoring bits of a backup is not easy and can cause issues if not done correctly.
How many Service Profiles are you trying to restore?  If few, it would be faster/safer to just manually re-create them.  If many, then I would suggest you download a new logical XML backup, and cut and paste the SP config from your old backup into the recent one, then re-import it with the "Merge" option.
Another option is to use the UCS PowerShell CLI to inject the config.  This takes a bit more skill (Knowledge of PowerShell and XML, but is an option.)
Robert
