Warning message
How to configure vmware Direct Path in UCS C240 with VIC1225
Oct 18th, 2013
Hi sir:
I have install ESXi 5.1 in UCS C240 with VIC 1225.
I have confured the ESXi5.1 with VM-FEX standard mode.
How can I change it to performance mode ?
sivaksiv Thu, 10/24/2013 - 01:36
  • Cisco Employee,
DirectPath I/O needs memory reservation to ensure that the VM's memory has not
been swapped out when the physical NIC tries to access the VM's memory. So, all
memory has to be reserved as it secures physical memory space for  a given VM.
http://blogs.vmware.com/performance/2010/12/performance-and-use-cases-of-vmware-directpath-io-for-networking.html
Configuring VMDirectPath I/O pass-through devices on an ESX host - http://kb.vmware.com/kb/1010789
Configuration Examples and Troubleshooting for VMDirectPath - http://www.vmware.com/pdf/vsp_4_vmdirectpath_host.pdf
-Siva
