Warning message
Chris Deren Fri, 10/18/2013 - 08:40
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
This has been asked many times here and you should be able to search for options. Basically there are 2:
if using H323/SIP for GW control use translation-rule reject on the GW
Or use "Route Next Hop By Calling Party Number" feature on CUCM translation pattern if you have CUCM 8+ (I think).
HTH,
Chris
Martin Gottfried Sun, 10/20/2013 - 12:18
Hi Jeff,
you can also use the ECC (External Call Control) to achive your needs.
For this, you have to have some external app which will handle it.
2Ring PHONE SERVICES (http://www.2ring.com/NewJuice) may be the one what you look for.
By the way, FREE or TRIAL license is obviously available.
Martin
