ASA-5505 Site-to-Site Not Working
Oct 18th, 2013
I am somewhat new to Cisco but to do have some experience. I am trying to connect two ASA 5505's together via site-to-site VPN. They are configured with public IPs and all other services are working. I have used the VPN wizard on both boxes successfully but the tunnels are not working. The two devices are on the Comcast network. Any help would be appreacited.
Site A: ASA 5505 w/50 User license
Site B: ASA 5505 w/10 User license
Site A Config:
ASA Version 8.2(5)
hostname *********************
enable password 6.De4e7UzES9wBPg encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.100.10 Web_Server
name 10.0.6.0 Ghost_Flower_Inside
name 10.0.5.0 San_Mateo_Inside
name 10.0.5.100 Any_Connect_100
name 10.0.5.101 Any_Connect_101
name 10.0.5.102 Any_Connect_102
name 10.0.5.103 Any_Connect_103
name 10.0.5.104 Any_Connect_104
name 10.0.5.105 Any_Connect_105
name 10.0.5.106 Any_Connect_106
name 10.0.5.107 Any_Connect_107
name 10.0.5.108 Any_Connect_108
name 10.0.5.109 Any_Connect_109
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 12
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.0.5.201 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 173.10.XXX.XXX 255.255.255.252
interface Vlan12
no forward interface Vlan1
nameif dmz
security-level 50
ip address 192.168.100.1 255.255.255.0
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 75.75.75.75
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network Any_Connect_DHCP
network-object host Any_Connect_100
network-object host Any_Connect_101
network-object host Any_Connect_102
network-object host Any_Connect_103
network-object host Any_Connect_104
network-object host Any_Connect_105
network-object host Any_Connect_106
network-object host Any_Connect_107
network-object host Any_Connect_108
network-object host Any_Connect_109
access-list outside_access_in extended permit tcp any interface outside eq www
access-list outside_access_in extended permit tcp any interface outside eq ssh
access-list outside_1_cryptomap extended permit ip San_Mateo_Inside 255.255.255.0 Ghost_Flower_Inside 255.255.255.0
access-list inside_nat0_outbound extended permit ip San_Mateo_Inside 255.255.255.0 Ghost_Flower_Inside 255.255.255.0
access-list inside_nat0_outbound extended permit ip object-group Any_Connect_DHCP any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool AnyConnectDHCPPool Any_Connect_100-10.0.5.110 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (dmz) 1 192.168.100.2 netmask 255.255.255.255
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface www Web_Server www netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 173.10.XXX.XXX 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.0.1.0 255.255.255.0 inside
http 10.1.10.0 255.255.255.0 outside
http San_Mateo_Inside 255.255.255.255 inside
http San_Mateo_Inside 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 173.12.XXX.XXX
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
vpn-sessiondb max-webvpn-session-limit 10
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh 10.0.1.0 255.255.255.0 inside
ssh San_Mateo_Inside 255.255.255.0 inside
ssh 10.1.10.0 255.255.255.0 outside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 10.0.5.10-10.0.5.30 inside
dhcpd dns 75.75.75.75 75.75.76.76 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
anyconnect-essentials
svc image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 1 regex "Intel Mac OS X"
svc profiles CATS disk0:/cats.xml
svc enable
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
dns-server value 75.75.75.75
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
webvpn
  svc profiles value CATS
username user1 password tTq7bIZ.C4x0j.qv encrypted privilege 15
username ********* password sPxon1E6hTszm7Ko encrypted privilege 15
tunnel-group 173.12.XXX.XXX type ipsec-l2l
tunnel-group 173.12.XXX.XXX ipsec-attributes
pre-shared-key *****
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:1751532c3624a6c2eec3c1ae0c31fe03
: end
Site B:
ASA Version 8.2(5)
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan12
nameif dmz
security-level 50
ftp mode passive
protocol-object udp
protocol-object tcp
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu dmz 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 173.10.242.182 1
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
svc enable
webvpn
username ************** password sPxon1E6hTszm7Ko encrypted privilege 15
: end
Dinesh Moudgil Sat, 10/19/2013 - 02:46
  • Cisco Employee,
Hi Kevin,
Both the sides have IP address of 173.10.XXX.XXX  on the respective Outside interfaces and you have configured the peers for 173.12.X.X.
Please ensure the correct IP addresses for VPN peers are configured , via the following command:
crypto map outside_map 1 set peer X.X.X.X
e.g. If you have 173.10.X.X on Site X and 173.12.X.X on Site Y , then
On Site X, peer would be
crypto map outside_map 1 set peer 173.12.X.X
and the tunnel-group will be
On Site Y, peer would be
crypto map outside_map 1 set peer 173.10.X.X
tunnel-group 173.10.XXX.XXX type ipsec-l2l
tunnel-group 173.10.XXX.XXX ipsec-attributes
Also , the nat exempt would be complimentary on each other i.e.
On Site X,
On Site Y,
access-list inside_nat0_outbound extended permit ip Ghost_Flower_Inside 255.255.255.0 San_Mateo_Inside 255.255.255.0
Hope that helps.
Dinesh Moudgil
