Do I really need QoS?
Oct 19th, 2013
Hey Guys,
I manage a Cisco network with 10x Cat 4506s and 1x Cat4510R all GIG POE. We run Cisco VoIP also.
My question is, do I really need QoS on the switches? We have no WAN sites, this is all on a campus fed by fiber. We have about 400 IP Phones, 500 computers, 100 servers, 100 printers, etc.
Any input or opinions are welcome.
Overall Rating: 5 (1 ratings)
islam.kamal Sat, 10/19/2013 - 16:00
  • Red, 2250 points or more
QOS one of the most important technology which is so important nowdays for traffics which are passed through network.As you mentioned above you have two types of traffic (Data and Voice) , you can do QOS which can help you to classify your traffic and do marking for the traffic , then at any congetion due to any problem on the network by QOS you can drop the least important traffic. The QOS should be done on your Cisco switches globally on the switches and per ports. Please refer to Cisco QOS SRND.
Thank you
Please rate all useful information
William Reed Mon, 10/21/2013 - 12:16
I have port channels to all my access switches from the core. Do I trust cos or dscp? Also do I enable command on each interface or the port-channel itself?
islam.kamal Mon, 10/21/2013 - 12:24
for trunks ports , you have to use trust DSCP , under the ports which connected to Cisco phones you have to use trust mls cos.Yes , you have to enable under physical interface. To enable port channel under port channel this is not supported on all devices , only support on cores as ASR , GSR , 6500.
Thank you
please rate all useful information
paolo bevilacqua Tue, 10/29/2013 - 08:19
  • Hall of Fame,
    Founding Member
No, as long it is a normally used LAN, you do not need QoS.
Joseph W. Doherty Thu, 11/07/2013 - 12:50
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Do you really need QoS?  That's an "it depends" answer.
If you have ports which ever congest to the degree it's adverse to the network service requirements of an application, then you may need QoS.  Notice I wrote "may need" because QoS cannot "solve" all congestion issues.  (BTW, there's also a widely held belief that adding bandwidth is the solution to all congestion issues.  Well it can be, but sometimes it can be outrageously more expensive, even on LANs, than using QoS to solve a congestion issue.)
Wayne DeNardi Mon, 01/06/2014 - 18:06
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 TelePresence
+5 to Joseph's answer above.
If you have no congestion, then no, you don't need QoS, as QoS only comes in to effect when a link is congested.
And then, depending on what other application is causing the congestion, there may be no advantage gained by enabling QoS (ie, if the packets from the other application are similarly marked).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
