Configuring the voice greetings (cisco 2800 series) (VoIP)
Oct 19th, 2013
Dear friends, please tell me. The problem seems to be simple, but due to my lack of experience is not yet solved:
The options are:
application
  service queue flash:app-b-acd-2.1.2.2.tcl
  param aa-hunt7 7777
  param aa-hunt8 8888
  param aa-hunt9 1000
  param queue-len 10
  param queue-manager-debugs 1
  param aa-hunt1 1111
  param aa-hunt2 2222
  param number-of-hunt-grps 9
  param aa-hunt3 3333
  param aa-hunt4 4444
  param aa-hunt5 5555
  param aa-hunt6 6666
  service aa flash:app-b-acd-aa-2.1.2.2.tcl
  paramspace english index 1
  param menu-timeout 6
  param dial-by-extension-option 0
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param max-extension-length 4
  param aa-pilot 2900
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt _aa1_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 600
  param voice-mail 5000
  param service-name queue
In which, as I understand it, for the number 2900 - set voicemail greeting - file _aa1_welcome.au. It is necessary also to set voicemail greeting (other than welcome to 2900) for the number 2911. Write a file with a greeting in flash:. Mobile 2911 only need To play a voice greeting (voice menu, the mail is not required). And further, can I create a similar configuration, following the example config for 2900? that is the format:
param aa-pilot 2911
param welcome-prompt _aa1_welcome2.au
Which parameters are sufficient for voice greeting? Is this the right way of thinking? If not, is there another option to make custom greetings for specific phones? Thank you.
Related Content
