Warning message
NO Traffic when the VPN and GRE tunnel up
Oct 20th, 2013
Please help me to fix this issue, vpn tunnel is up, but no encrypt traffic on the PE site and the GRE tunnel can not ping.
PE config:
G-PE11#sh run
Building configuration...
Current configuration : 6660 bytes
! Last configuration change at 16:29:23 Beijing Sun Oct 20 2013 by gssnetnoc
version 15.3
hostname PE11
redundancy
crypto isakmp policy 10
encr 3des
authentication pre-share
group 5
crypto isakmp key G-20131015-PE address 0.0.0.0
crypto isakmp keepalive 10
crypto isakmp aggressive-mode disable
crypto ipsec transform-set G-PE-trans esp-3des esp-sha-hmac
mode tunnel
crypto dynamic-map G-PE-dmap 10
set transform-set G-PE-trans
crypto map dynamic-map local-address Loopback200
crypto map dynamic-map 10 ipsec-isakmp dynamic G-PE-dmap
interface Loopback200
ip address 22.126.229.125 255.255.255.255
interface Tunnel201
ip address 10.0.96.5 255.255.255.252
ip mtu 1400
load-interval 30
tunnel source Loopback200
tunnel destination 10.0.99.101
tunnel key 10201
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.244.16.6 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.244.16.5
CPE config:
ADSL#sh run
Current configuration : 2972 bytes
! Last configuration change at 16:39:59 BJ Sun Oct 20 2013
version 15.1
hostname ADSL
encr 3des
group 5
crypto isakmp key G-20131015-PE address 22.126.229.125
crypto ipsec transform-set G-CPE-trans esp-3des esp-sha-hmac
mode transport
crypto map G1310201-Static-Map local-address Dialer0
crypto map G1310201-Static-Map 20 ipsec-isakmp
set peer 22.126.229.125
set transform-set G-CPE-trans
match address G-1310201-ACL
interface Loopback201
ip address 10.0.99.101 255.255.255.255
interface Tunnel1310201
ip address 10.0.96.6 255.255.255.252
ip mtu 1400
load-interval 30
tunnel source Loopback201
tunnel destination 22.126.229.125
tunnel key 10201
interface FastEthernet0/0
no ip address
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1
ip address 192.168.0.100 255.255.255.0
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username 154432 password 0 576
ip route 0.0.0.0 0.0.0.0 10.0.96.5
ip route 22.126.229.125 255.255.255.255 Dialer0
ip access-list extended G-1310201-ACL
permit gre host 10.0.99.101 host 22.126.229.125
From CPE's info:
ADSL#show crypto ipsec sa
interface: Dialer0
    Crypto map tag:G1310201-Static-Map, local addr 221.221.155.96
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.0.99.101/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (22.126.229.125/255.255.255.255/47/0)
   current_peer 22.126.229.125 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 407, #pkts encrypt: 407, #pkts digest: 407
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 1, #recv errors 0
     local crypto endpt.: 221.221.155.96, remote crypto endpt.: 22.126.229.125
     path mtu 1492, ip mtu 1492, ip mtu idb Dialer0
     current outbound spi: 0x43D7FFCE(1138229198)
     PFS (Y/N): N, DH group: none
G-PE11#show cry ip sa
interface: Loopback200
    Crypto map tag: dynamic-map, local addr 22.126.229.125
   local  ident (addr/mask/prot/port): (22.126.229.125/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (10.0.99.101/255.255.255.255/47/0)
   current_peer 221.221.155.96 port 500
     PERMIT, flags={}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 524, #pkts decrypt: 524, #pkts verify: 524
    #send errors 0, #recv errors 0
     local crypto endpt.: 22.126.229.125, remote crypto endpt.: 222.128.169.253
     plaintext mtu 1462, path mtu 1514, ip mtu 1514, ip mtu idb Loopback200
     current outbound spi: 0x0(0)
GRE Tunnel Ping:
From PE to CE:
G-PE11#ping 10.0.96.6
Sending 5, 100-byte ICMP Echos to 10.0.96.6, timeout is 2 seconds:
Success rate is 0 percent (0/5)
