10-21-2013 12:29 AM - edited 02-21-2020 05:01 AM
Hi dears
we buy 2 cisco ASA 5555-x with IPS module. when i write show module in each ASA.
ASA1:
Mod Card Type Model Serial No.
0 ASA 5555-X with SW, 8 GE Data, 1 GE Mgmt ASA5555 FCH1727J1VD
ips ASA 5555-X IPS Security Services Processor ASA5555-IPS FCH1727J1VD
Mod MAC Address Range Hw Version Fw Version Sw Version
0 7c69.f68f.6bdc to 7c69.f68f.6be5 1.0 2.1(9)8 8.6(1)2
ips 7c69.f68f.6bda to 7c69.f68f.6bda N/A N/A 7.1(4)E4
Mod SSM Application Name Status SSM Application Version
ips IPS Up 7.1(4)E4
Mod Status Data Plane Status Compatibility
0 Up Sys Not Applicable
ips Up Up
Mod License Name License Status Time Remaining
ips IPS Module Enabled perpetual
ASA2:
ciscoasa# show module
0 ASA 5555-X with SW, 8 GE Data, 1 GE Mgmt ASA5555 FCH1729J7Z5
ips Unknown N/A FCH1729J7Z5
cxsc Unknown N/A FCH1729J7Z5
0 c08c.6015.26c2 to c08c.6015.26cb 1.0 2.1(9)8 9.1(1)
ips c08c.6015.26c0 to c08c.6015.26c0 N/A N/A
cxsc c08c.6015.26c0 to c08c.6015.26c0 N/A N/A
ips Unknown No Image Present Not Applicable
ips Unresponsive Not Applicable
cxsc Unresponsive Not Applicable
ips IPS Module Disabled perpetual
what is a problem in second ASA IPS? is this physical problem on IPS?
Thanks.
11-05-2013 04:24 PM
Double check your order. If the second unit was indeed purchased with IPS, it has a hardware problem and you should contact the TAC for an RMA.
It appears to have the SSD for CX module but is not imaged to support that.
11-07-2013 08:54 AM
Marvin, could it also be that the liscence for the second 5555 is not setup for IPS? i see the License is set as "Disabled" which leads me to believe that it may not have a proper key.
11-10-2013 06:51 PM
I'm not positive but I think the license status "disabled" is s secondary effect. The card type "unknown" would be more troubling to me.
I'd open a TAC case on it if you've verified the order included IPS.
