Warning message
anirudh.wna Mon, 10/21/2013 - 01:53
is it a new switch.
check if,
1.if you have the settings right in hyperterminal/putty/minicom etc..
2.if a different console cable is workig in this switch.
3 you are connecting to the correct console port !!
4.if you have any ip address configure in the switch, try to telnet/ssh to it.
junaid haroon Mon, 10/21/2013 - 02:37
HI,
my switch is old one
i have checked all senarios but still facing same issue
anirudh.wna Mon, 10/21/2013 - 02:43
isn,t there any config inside. what is the model of your switch. did'nt you create any int vlan with any ip?? can you recall.. by any chance does  your switch support usb console cable??
