10-21-2013 01:32 AM - edited 03-11-2019 07:53 PM
Hi All,
Guys, I would like to ask you one question regarding QoS. I have Cisco 5505 K9 for 50 host with standard license.
Is it possbile to configure QoS on such kind of device?
Thank you in adance!
Solved! Go to Solution.
10-21-2013 06:28 AM
The following table shows the licensing requirements for this feature:
Model | License Requirement |
All models | Base License. |
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/conns_qos.html#wp1112081
Patrick
10-21-2013 06:28 AM
Patrick
10-21-2013 07:37 AM
Patrick, thank you for your prompt replay and explanation.
I would like to ask you one more question regarding the ASA.
In my organization we are planning to do BYOD regulation. Just to go for simple solution, Cisco ASA 5505 with base licenses, support some kind of guest WiFI vlan? I mean that, people which will be connected to the WiFI should not access to the corporate resources.
I know, there is lot of solution for BYOD like http://www.air-watch.com/ http://boxtone.com/ and etc. however, i would like to go for cheap solution.
Any advices or recommendation?!
Thank you in adavnce!
