BGP Attribute for outgoing Traffic
Answered Question
Oct 22nd, 2013
Dear,
I am have the attached diagram:
- There is two links between routers.
- I have intiate BGP Session between them. for incoming traffic I use prepend and it worked fine.
Now, my objective to use the BGP to route network 10.8.8.0/29 on link -1 and network 10.10.10.0/29 on Link-2  on normal operation. In case Link one down I want to route network 10.8.8.0/29 to the second link. In case link-2 down, network 10.10.10.0/29 should be routed to link-1.
Which attribute I should use for this and how this can be acheived to deal with the source IP.
Thanks.
MS
Correct Answer by Harold Ritter about 3 years 9 months ago
The failover will work without IP SLA if you shutdown the interface on the internal router. You need IP SLA if you want to test the entire path between the two routers. For instance, if the external router fails, the internal router will not know since it is connected to the switch and not directly to the internal router. That is where IP SLA can help.
Overall Rating: 5 (1 ratings)
Harold Ritter Tue, 10/22/2013 - 06:19
  • Cisco Employee,
BGP could help you to direct incoming traffic (traffic coming from the Internet) over one link or the other based on the destination network (10.8.8.0/29 or 10.10.10.0/29) but it will not help if you are trying to route outgoing traffic based on the source address. You would need to use Policy Based Routing (PBR) to achieve that.
alshamlan Tue, 10/22/2013 - 06:30
Thanks Harold,
Can you please explain how we can achive it using the PBR? one example .
regards
dc-csa-blr Tue, 10/22/2013 - 06:39
Hi Alshamlan,
Can you please share with me your BGP Prepend configuration because i also configured bgp as-path prepend in my router for manage incoming traffic but i think it is not work properly, we are using multiple e-BGP in single homed that's why.
Thanks in ADV,
Harold Ritter Tue, 10/22/2013 - 07:32
  • Cisco Employee,
It would look something like this.
interface Ethernet0/0
ip address 10.8.8.1 255.255.255.248
ip policy route-map pbr1
interface Ethernet1/0
ip address 10.10.10.1 255.255.255.248
ip policy route-map pbr2
interface Ethernet2/0
description Link1
ip address 192.168.1.2 255.255.255.252
interface Ethernet3/0
description Link2
ip address 192.168.2.2 255.255.255.252
route-map pbr1 permit 10
set ip next-hop 192.168.1.1 192.168.2.1
set ip next-hop verify-availability
route-map pbr2 permit 10
set ip next-hop 192.168.2.1 192.168.1.1
alshamlan Tue, 10/22/2013 - 07:53
Dear Harold,
I tried the BPR but it didnt work with me any advice?
DC, I will post the prepend configuration tomorrow.
smitesh kharecha Tue, 10/22/2013 - 08:12
  • Silver, 250 points or more
You need to do conditional BGP advertisement for what you want to acheive.
In BGP you have to use advertise-map option, for more information you can try cisco docs.
Smitesh
PS: Please rate helpful posts
Harold Ritter Tue, 10/22/2013 - 08:28
  • Cisco Employee,
Hi Smitesh,
This would take care of the incoming traffic. The original poster asked about the outgoing traffic.
smitesh kharecha Tue, 10/22/2013 - 08:36
Hi Harold,
Yup, you are correct. Maybe my ignorance in reading the question correctly.
You can use weight or local pref in that case.
Smitesh
Harold Ritter Tue, 10/22/2013 - 09:04
  • Cisco Employee,
Hi Smitesh,
Weight and local preference will not help either as the requirement is to route the outgoing traffic based on the source address rather than on the destination address. BGP won't help in this case but PBR will.
smitesh kharecha Tue, 10/22/2013 - 09:21
Harold,
Seems like I never understood the question correctly.
I re-read the question again and you are correct that OP wants source based routing, and PBR is simple and elegant solution.
Smitesh
Harold Ritter Tue, 10/22/2013 - 08:27
  • Cisco Employee,
What platform is the router performing PBR?
Is CDP running between the two routers?
Can you post the relevant configuration. Can you post the output for "sh route-map pbr1" and "sh route-map pbr2"
alshamlan Wed, 10/23/2013 - 06:29
Hi Harold,
Router is 1841
CDP enable on both routers, however, there is a switch in between both router that is used for SVI on the first router as below
(ROUTER-1) -------------------trunk---------------------(SWITCH)----------------2 access ports-----------------(CISCO-1841)
ROUTER-1841#show route-map pbr1
route-map pbr1, permit, sequence 10
  Match clauses:
  Set clauses:
  Policy routing matches: 2 packets, 134 bytes
ROUTER-1841#show route-map pbr2
route-map pbr2, permit, sequence 10
  Match clauses:
  Set clauses:
  Policy routing matches: 1 packets, 60 bytes
Harold Ritter Wed, 10/23/2013 - 14:25
  • Cisco Employee,
"set ip next-hop verify-availability" uses CDP to verify the status of the next hop. So this command will not work in your scenario. You can try removing this command just to verify that PBR works for you. If you want your traffic from link1 to failover to link2 and vice versa in case of failure, I would recommend that you use "set ip next-hop verify-availability" in conjonction with tracking options. The following document shows a good example of how that can be done.
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
Harold Ritter Wed, 10/23/2013 - 16:22
  • Cisco Employee,
The document I sent contained the old syntax for IP SLA. The feature used to be called Cisco Service Assurance Agent (SAA) and was later renamed to Cisco IP SLA. The syntax also changed. Here's a document explaining the new syntax. The PBR syntax does not change though and you can still use the previous document I provided to configure that part.
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html
alshamlan Wed, 10/23/2013 - 22:49
Thanks Harold,
Please the traffic is not flow as we required 10.8.8.0/29 to have the next hop as 192.168.1.1 and 10.10.10.0/29 to have next hop as 192.168.2.1, any hin on this?
Once this traffic flow work, I will test the IP-SLA.
Morevoer, Can we thing about it to do it from the other router? Since network 10.10.10.0/29 and 10.8.8.80/29 will be destinaiton to the second router??
Harold Ritter Thu, 10/24/2013 - 06:14
  • Cisco Employee,
The initial configuration I provided should work. Can you please post the relevant configuration that you applied. As for load balancing in the incoming direction, this part can be addresses with BGP AS path prepending.
alshamlan Sun, 10/27/2013 - 00:02
Hi Harld,
See the configuration.
I have created two loop back interface and applied the route map on then for my testing now. instead og having two physical interces.
interface Loopback0
interface Loopback1
See the ip route
B*    0.0.0.0/0 [20/0] via 192.168.1.1, 2d18h
      10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
See ip bgp
ROUTER1841#sh ip bgp
BGP table version is 26, local router ID is
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          192.168.1.1                           0            77887 66556 i
*                       192.168.2.1                           0            77887 66556 i
*> 10.8.8.0/29        0.0.0.0                  0         32768 i
*> 10.10.10.0/29    0.0.0.0                  0         32768 i
Harold Ritter Sun, 10/27/2013 - 18:49
  • Cisco Employee,
Applying the PRB route-map to the loopback interface will not work. To apply PBR to the traffic sourced from the router. you will need to use the command "ip local policy route-map" in global mode. Also, do not forget to remove "set ip next-hop verify-availability" or use IP SLA in conjunction
with it. Aspreviously mentioned, CDP will not work in your case since the router are separated by a switch.
alshamlan Wed, 10/30/2013 - 03:28
Hi Harold,
It is working with me now when I tested through the physical interfaces not on loopback and removed the (( ip next-hop verify-availability )) . Moreover, I ahve tested the failover also and it worked as we required without any ip sla conficuration which make me suprised. All what I have changed is removed the (( ip next-hop verify-availability )) and kept one next hop on pbr1 as you can see below, Can you please advice how the failover worked without and ip sla? is it beacuse of BGP incoming traffic working fine that influnce the outgoing to worked?
description Link1
description Link2
Senario tested:
1- Both links UP
subnet 1 going through link-1
subnet 2 going through link-2
2- Link-1 DOWN
subnet 1 going through link-2
the failover of subnet-1 to link-2 was approximately 3 minutes.
3- Link-2 DOWN
subnet 2 going through link-1
the failover of subnet-2 to link-1 was approximately 3 minutes.
Correct Answer
Harold Ritter Wed, 10/30/2013 - 06:22
  • Cisco Employee,
alshamlan Thu, 10/31/2013 - 00:13
Hi Harold,
yes you are right. Therefore, I have to implment the IP SLA. I will do and share the result.
regards
alshamlan Sun, 11/03/2013 - 05:21
Hi Harold,
Thanks for your guidance,
I have implmented the SLA and tested it is working fine now , below the configuraiton.
interface FastEthernet0/0
description uplink-for-Link-1
interface FastEthernet0/1
interface FastEthernet0/1/0
description Downlink-for-Link-1
interface FastEthernet0/1/1
description Downlink-for-Link-2
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
## SLA for Link-1 ##
ip sla 1
icmp-echo 192.168.1.1 source-ip 192.168.1.2
threshold 15
timeout 15000
frequency 15
ip sla schedule 1 life forever start-time now
## SLA for Link-2 ##
ip sla 2
icmp-echo 192.168.2.1 source-ip 192.168.2.2
threshold 15
timeout 15000
frequency 15
ip sla schedule 2 life forever start-time now
## Route MAP for Link-1 ##
set ip next-hop verify-availability 192.168.2.1 1 track 2
## Route MAP for Link-2 ##
set ip next-hop verify-availability 192.168.1.1 1 track 1
dc-csa-blr Wed, 10/23/2013 - 22:51
Hi Alshamlan,
Can you please share with me how to manage incomming traffic by as-path prepend.
Pl share your configuration.
Thanks in ADV,
alshamlan Wed, 10/23/2013 - 23:05
Dear DC,
router bgp 65517
bgp log-neighbor-changes
network 10.8.8.0 mask 255.255.255.248
network 10.10.10.0 mask 255.255.255.248
neighbor 192.168.1.1 remote-as 65588
neighbor 192.168.1.1 description ### MW-LINK ###
neighbor 192.168.1.1 update-source FastEthernet0/0
neighbor 192.168.1.1 soft-reconfiguration inbound
neighbor 192.168.1.1 prefix-list BFC_IN in
neighbor 192.168.1.1 prefix-list BFC_OUT out
neighbor 192.168.1.1 route-map PEND_32_FB out
neighbor 192.168.2.1 remote-as 65588
neighbor 192.168.2.1 description ###-Fiber-Main-LINK ###
neighbor 192.168.2.1 update-source FastEthernet0/1
neighbor 192.168.2.1 soft-reconfiguration inbound
neighbor 192.168.2.1 prefix-list BFC_IN in
neighbor 192.168.2.1 prefix-list BFC_OUT out
neighbor 192.168.2.1 route-map PEND_24_MW out
ip route 10.8.8.0 255.255.255.248 Null0
ip route 10.10.10.0 255.255.255.248 Null0
ip prefix-list 24_MW seq 6 permit 10.8.8.0/29
ip prefix-list 32_FB seq 7 permit 10.10.10.0/29
ip prefix-list BFC_OUT seq 6 permit 10.8.8.0/29
ip prefix-list BFC_OUT seq 7 permit 10.10.10.0/29
ip prefix-list BFC_IN seq 5 permit 0.0.0.0/0
route-map PEND_24_MW permit 10
match ip address prefix-list 24_MW
set as-path prepend 65517 65517 65517
route-map PEND_24_MW permit 11
route-map PEND_32_FB permit 12
match ip address prefix-list 32_FB
route-map PEND_32_FB permit 13
