Warning message
Block internal calls on CME
Answered Question
Oct 23rd, 2013
Is there anyway to block internal calls on CME?
For example, phone 1000 no call to phone 1001 in same Router.
Correct Answer by islam.kamal about 3 years 10 months ago
Yes , i have already shared with u all links for COR and i provided u with two solution one for COR and other for after hours.
Thank you
Please rate all useful information
Overall Rating: 4.8 (3 ratings)
islam.kamal Wed, 10/23/2013 - 07:11
  • Red, 2250 points or more
I have configured below some solutions , i hope all help you:-
1-
voice translation-rule 1
rule 1 reject /1000/
voice translation-profile REJECT
translate calling 1
Then go to the ephone-dn (which has number 1001) . The below configuration based on your IOS.
ephone-dn  50
     number 1001
     translation-profile incoming REJECT
or
ephone-dn  50
     number 1001
     translate calling REJECT
2-
telephony-serv
  after-hours block pattern 1 1000  7-24
Then under ephone with DN other than 1001 configure  after-hours exempt CLI.This will block only 1001 , when you enable after-hours exempt under other phones this will allow other phones calls 1000.
Thank you
Please rate all useful informaion
Correct Answer
islam.kamal Wed, 10/23/2013 - 11:00
Thank you
