10-23-2013 07:33 AM - edited 03-16-2019 08:02 PM
I have a 2821 router that is connected to a SIP trunk. This router also has a PRI interface that is connected to a Mitel PBX. The Mitel uses the router has a primary connection to the PSTN.
The Mitel will send calling party number most of the time, but some times it does not. All calls that are sent to the SIP provider without a calling party number are dropped. I know if can override the calling party number by using the clid commad on the dail peer, however is it possible to only override the calling party number if i don't recieve one from the Mitel? It I do recieve a calling party number like a DID I want to forward it along in the SIP call.
Thanks.
Solved! Go to Solution.
10-23-2013 08:08 AM
You should be able to do that with a voice translation rule that matches an empty ANI.
voice translation-rule 30rule 1 /^\+631689\(....\)$/ /01689\1/rule 2 /^$/ /555666777/
voice translation-profile PSTN-OUTtranslate calling 30
First rule is to match any real number from the PBX, adapt that to fit your needs. The second rule matches a null value and changes that to 555666777, adapt that to what you'd like to send to your Telco.
Please remember to rate helpful responses and identify helpful or correct answers.
10-23-2013 08:08 AM
10-23-2013 08:44 AM
Perfect, thanks.
10-23-2013 09:24 AM
Your welcome, thanks for the nice rating.
