Warning message
VPN Client Will Not Load
Oct 23rd, 2013
Trying to load VPN client on my Windows7 machine.  When I execute setup.exe I get one pop up asking if I want to run the program and then nothing happens.  Program never loads and I do not get any errors.
Rene'
andduart Thu, 10/24/2013 - 18:55
Looks like a local problem, maybe try from scratch and check how it goes. Also, make sure to disable possible protection on the PC....
Let us know how it goes
andduart Thu, 10/24/2013 - 19:00
Also,
Please make sure if you are downloading the proper package, verify if you have W7 32 or 64 bits.
VPN Client Software for x86 64-bit version of Vista and Windows 7
vpnclient-winx64-msi-5.0.07.0440-k9.exe
VPN Client Software for x86 32-bit version of XP/Vista/Windows 7
vpnclient-win-msi-5.0.07.0410-k9.exe
