Eigrp metric count
Answered Question
Oct 24th, 2013
hi,
All router running default eigrp configuration, Router 3 has 2 successor to reach r2 loop (10.1.102.2),and it both FD is 2681856, how it got 2 successor becoz  from router3 se 1/1 has two hop to reach r2 loop and from se 1/0 has only one hop. Your suggestion plz.
R3#sh ip eigrp topology 10.1.102.0/29
IP-EIGRP (AS 100): Topology entry for 10.1.102.0/29
  State is Passive, Query origin flag is 1, 2 Successor(s), FD is 2681856
  Routing Descriptor Blocks:
  10.1.103.1 (Serial1/1), from 10.1.103.1, Send flag is 0x0
      Composite metric is (2681856/2169856), Route is Internal
      Vector metric:
        Minimum bandwidth is 1544 Kbit
        Total delay is 40000 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
  10.1.203.2 (Serial1/0), from 10.1.203.2, Send flag is 0x0
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
Correct Answer by daniel.dib about 3 years 9 months ago
R2 does not "own" the subnet. It is owned by both R1 and R2 so they both advertise it directly to R3.
Daniel Dib
CCIE #37149
Correct Answer by waqas younas about 3 years 9 months ago
Dear All see the result below. Hopefully confusions are cleared.Goodluck.
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
REGARDS
WAQAS YOUNAS
CCIE#27815
Routing&Switching
Service Provider
Overall Rating: 5 (2 ratings)
daniel.dib Thu, 10/24/2013 - 02:56
  • Silver, 250 points or more
The route you are looking at is the subnet connecting R1 and R2 (10.1.102.0/29). Both R1 and R2 are directly connected to this so R3 gets the same route from both of them with the same metric.
Daniel Dib
CCIE #37149
feroz syed Thu, 10/24/2013 - 03:12
But Router 3 has directly connected to R2 (R2-->R2 20000+20000)so it should be a successor, how it select second successor by going from R3-->R1-->R2 (20000+20000+20000).
Correct Answer
daniel.dib Thu, 10/24/2013 - 05:47
Daniel Dib
CCIE #37149
Correct Answer
waqas younas Thu, 10/24/2013 - 04:34
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
REGARDS
WAQAS YOUNAS
CCIE#27815
Routing&Switching
Service Provider
