Warning message
Rate-limit seems to not work
Oct 24th, 2013
When we use Aspera, it maxes out our bandwidth and we cannot do anything else while the download is going on.
3220ASA1# sh conn add 192.168.0.105 prot udp
110 in use, 509 most used
UDP outside 153.7.233.153:33001 inside 192.168.0.105:60064, idle 0:00:00, bytes 573048376, flags -
I want to rate-limit the UDP port 33001 that aspera uses, here is that part of my config. I applied the QoS to both the inside and outside interface for port 33001.
ASA Version 8.6(1)
access-list outside_mpc extended permit udp any any eq 33001
access-list inside_mpc_1 extended permit udp any any eq 33001
class-map inside-class
match access-list inside_mpc_1
class-map outside-class
match access-list outside_mpc
policy-map outside-policy
class outside-class
  police input 100000 1500
  police output 100000 1500
policy-map inside-policy
class httptraffic
  inspect http http_inspection_policy
class inside-class
service-policy outside-policy interface outside
service-policy inside-policy interface inside
Do I have this wrong? The ASDM is still showing traffic as much higher than the 100kbps I want to limit to.
Julio Carvajal Thu, 10/24/2013 - 13:41
  • Purple, 4500 points or more
Hello Dru,
I would actually do it like this
class outside-class
class httptraffic
class inside-class
Then I would apply the service-policy and then do clear local-host
Let me know how it goes
Jcarvaja
Dru Goradia Thu, 10/24/2013 - 17:14
After speaking with TAC we were able to police the traffic internally but as it's UDP the source server just kept throwing the packets at us, maxing out the bandwith. I was told that the only workaround is to get the ISP to limit it.
Julio Carvajal Thu, 10/24/2013 - 18:22
Hello Dru,
What do U mean?
Who is the one that innitiates the connection, the server on the inside of an outside user???
Did u Try what I suggested?
Todd Kelly Tue, 04/19/2016 - 14:09
Having the same issues. Did the recommendation from Julio help you? I would like to know if this has resolved your issue.
Thanks.
Todd
Related Content
