routing between router and core 4507r switch
Oct 24th, 2013
   I am connecting  our campus core switch 4707r to a router through a layer 3 interface and using eigrp.  I could not bring up the interfaces between the router and switch. Is there something I missed? i am using a crossover cable to connect them. any help will be appreciated. i saw the  link is  green on the router end.
Here is the router config:
interface GigabitEthernet0/1
description to WACAT4K-A
ip address 10.12.11.1 255.255.255.252
duplex full
speed 100
router eigrp 2
network 10.0.0.0
passive-interface default
no passive-interface GigabitEthernet0/1
here is the 4507r:
interface GigabitEthernet1/2
description WA3500-A1
no switchport
ip address 10.12.11.2 255.255.255.252
qos trust dscp
router eigrp 2
no auto-summary
network 10.0.0.0
Can I use any switch port as a layer 3 interface and connect it to a router?
thanks,
Alison
rfalconer.sffcu Thu, 10/24/2013 - 16:29
  • Bronze, 100 points or more
What kind of router is it?
You shouldn't need a cross-over cable between a switch and router. Did you try a straight-through?
You can set the interface to L3 on the switch. Whether or not it supports a routing protocol will be determined by the type of supervisor and version of software license you have.
Related Content
