3825 Setup DHCP and Nat
Oct 24th, 2013
Looking for help on on how to setup a 3825 router connecting to an isp via metro ethernet.  The public ip pool given to me by the ISP is a /26.  I would like to have my network equipment(10 3550-48 switches) on public ips and then my end users(workstations plugged into 3550 switches) on a natted .10 network directed to my isp for internet access.
paolo bevilacqua Thu, 10/24/2013 - 21:18
  • Hall of Fame,
    Founding Member
Wrong forum, post in "WAN and routing". You can move your posting with the Actions panel on the right.
jtothemak Fri, 10/25/2013 - 05:24
Thanks, I moved it.  Now just need some help on a solution.
jtothemak Fri, 10/25/2013 - 10:24
Here is the config I have so far.  I will be doing a vlan per building, with each building on there own ip block via dhcp.  Can someone please let me know if I am making an errors.  Also for the vlan sub interfaces do I need ip nat inside?  I decided to use static nat for remote access to my 3550 switches.
hostname HueRouter
ip subnet-zero
ip dhcp excluded-address 10.0.0.1 10.0.0.50
ip dhcp pool hue
  network 10.0.0.0 255.0.0.0
  dns-server 8.8.8.8 8.8.4.4
  default-router 10.0.0.1
interface FastEthernet0
ip address 10.0.0.1 255.0.0.0
no ip directed-broadcast
ip nat inside
no ip mroute-cache
interface FastEthernet0/0.10
description Building 1
encapsulation dot1Q 10
ip address 10.10.1.0 255.255.255.0
no snmp trap link-status
interface FastEthernet0/0.20
description  Building 2
encapsulation dot1Q 20
ip address 10.10.2.0 255.255.255.0
interface FastEthernet0/0.30
description  Building 3
encapsulation dot1Q 40
ip address 10.10.3.0 255.255.255.0
interface FastEthernet0/0.40
description  Building 4
ip address 10.10.4.0 255.255.255.0
interface FastEthernet0/0.50
description  Building 5
encapsulation dot1Q 50
ip address 10.10.5.0 255.255.255.0
interface FastEthernet0/0.60
description  Building 6
encapsulation dot1Q 60
ip address 10.10.6.0 255.255.255.0
interface FastEthernet0/0.70
description  Building 7
encapsulation dot1Q 70
ip address 10.10.7.0 255.255.255.0
interface FastEthernet0/0.80
description  Building 8
encapsulation dot1Q 80
ip address 10.10.8.0 255.255.255.0
interface FastEthernet0/0.90
description  Building 9
encapsulation dot1Q 90
ip address 10.10.9.0 255.255.255.0
interface FastEthernet0/0.100
description  Building 10
encapsulation dot1Q 100
ip address 10.10.10.0 255.255.255.0
interface FastEthernet1
ip address 1.1.1.1 255.255.255.128
ip nat outside
ip nat inside source static 10.0.0.2 1.1.1.3
ip nat inside source static 10.0.0.3 1.1.1.4
ip nat inside source static 10.0.0.4 1.1.1.5
ip nat inside source static 10.0.0.5 1.1.1.6
ip nat inside source static 10.0.0.6 1.1.1.7
ip nat inside source static 10.0.0.7 1.1.1.8
ip nat inside source static 10.0.0.8 1.1.1.9
ip nat inside source static 10.0.0.9 1.1.1.10
ip nat inside source static 10.0.0.10 1.1.1.11
ip nat inside source static 10.0.0.11 1.1.1.12
ip nat inside source list 1 interface FastEthernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet1
no ip http server
access-list 1 permit 10.0.0.0 0.255.255.255
line vty 0 15
password password_here
enable secret password_here
service password-enc
Kelvin Willacey Fri, 10/25/2013 - 11:20
  • Bronze, 100 points or more
You will need 'ip nat inside' on the internal interfaces.
jtothemak Fri, 10/25/2013 - 12:17
Thank you,  I was thinking the sub interfaces needed but was unsure.  Anything else that needs attention?
Kelvin Willacey Fri, 10/25/2013 - 12:52
Everything else looks fine, I have two comments though. If possible I would use the actual IP address for the ISP gateway in your default route rather than the interface. You can also think about using static PAT rather than opening up every port to those hosts.
Richard Burts Fri, 10/25/2013 - 12:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have you actually got this configuration on a router? I would think that a Cisco router would not accept this on a main interface ip address 10.0.0.1 255.0.0.0 and this on a subinterface ip address 10.10.1.0 255.255.255.0 because of the overlapping address assignments.
Also I am not sure that you could have these 10 subnets all using the same pool of the /8 address. I would wonder if you will not need 10 individual pools configured.
If you do have it configured and it does work then please post back to the forum confirming that it does work.
Rick
jtothemak Fri, 10/25/2013 - 13:21
It is not a running config yet.  I will not have access to the gear till the day it is deployed which is what is making me nervous and cutting over a live system.
I ran a simulator GNS3 and was able to give it 10.10.1.1 255.255.255.0 on the sub interface with 10.0.0.1 255.0.0.0 and it let it.  As soon as did a no shut it gave me an overlap.
I will make a pool for vLAN1 and a seperate pool for each other VLAN.
Any other issues?  Do I have routing done correctly?
Richard Burts Fri, 10/25/2013 - 13:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If it gave you an overlap when you did a no shut then I would be very nervous about trying to use this concept for a live cutover.
I had not looked closely at your routing. But now that I do I absolutely do agree with the previous suggestion that you should not use ip route 0.0.0.0 0.0.0.0 FastEthernet1. There are several reasons why this is not a good thing to do and that you should specify the IP of the next hop in the static default route.
Rick
Kelvin Willacey Fri, 10/25/2013 - 14:16
I missed the overlap and the DHCP scope. You would definitely need a scope for each subnet as Richard suggested. Do you need an IP address on the physical interface? Is this one of your subnets for the buildings? You said ten buildings and you already have ten vlans and sub interfaces.
jtothemak Fri, 10/25/2013 - 14:28
Here is updated config adding a pool for each Vlan.  Will my routing statement and access list 1 work or do I need to do one for each subnet?
hostname HueRouter
ip subnet-zero
ip cef
ip cef load-sharing algorithm original
no ip dhcp conflict logging
ip dhcp excluded-address 10.0.50.1 10.0.50.100
ip dhcp excluded-address 10.0.1.1 10.0.1.20
ip dhcp excluded-address 10.0.2.1 10.0.2.20
ip dhcp excluded-address 10.0.3.1 10.0.3.20
ip dhcp excluded-address 10.0.4.1 10.0.4.20
ip dhcp excluded-address 10.0.5.1 10.0.5.20
ip dhcp excluded-address 10.0.6.1 10.0.6.20
ip dhcp excluded-address 10.0.7.1 10.0.7.20
ip dhcp excluded-address 10.0.8.1 10.0.8.20
ip dhcp excluded-address 10.0.9.1 10.0.9.20
ip dhcp excluded-address 10.0.10.1 10.0.10.20
ip dhcp pool lan1
  network 10.10.50.0 255.255.255.0
  default-router 10.0.50.1
  lease 0 3
ip dhcp pool bld1
  network 10.10.1.0 255.255.255.0
  default-router 10.0.1.1
  lease 0 3
ip dhcp pool bld2
  network 10.10.2.0 255.255.255.0
  default-router 10.0.2.1
  lease 0 3
ip dhcp pool bld3
  network 10.10.3.0 255.255.255.0
  default-router 10.0.3.1
  lease 0 3
ip dhcp pool bld4
  network 10.10.4.0 255.255.255.0
  default-router 10.0.4.1
  lease 0 3
ip dhcp pool bld5
  network 10.10.5.0 255.255.255.0
  default-router 10.0.5.1
  lease 0 3
ip dhcp pool bld6
  network 10.10.6.0 255.255.255.0
  default-router 10.0.6.1
  lease 0 3
ip dhcp pool bld7
  network 10.10.7.0 255.255.255.0
  default-router 10.0.7.1
  lease 0 3
ip dhcp pool bld8
  network 10.10.8.0 255.255.255.0
  default-router 10.0.8.1
  lease 0 3
ip dhcp pool bld9
  network 10.10.9.0 255.255.255.0
  default-router 10.0.9.1
  lease 0 3
ip dhcp pool bld10
  network 10.10.10.0 255.255.255.0
  default-router 10.0.10.1
  lease 0 3
ip address 10.10.50.1 255.255.255.0
ip nat inside
no ip mroute-cache
ip address 10.10.1.1 255.255.255.0
ip nat inside
ip address 10.10.2.1 255.255.255.0
ip nat inside
ip address 10.10.3.1 255.255.255.0
ip nat inside
ip address 10.10.4.1 255.255.255.0
ip nat inside
ip address 10.10.5.1 255.255.255.0
ip address 10.10.6.1 255.255.255.0
ip nat inside
ip address 10.10.7.1 255.255.255.0
ip nat inside
ip address 10.10.8.1 255.255.255.0
ip nat inside
ip address 10.10.9.1 255.255.255.0
ip nat inside
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
ip nat outside
ip nat inside source static 10.0.50.2 1.1.1.3
ip nat inside source static 10.0.50.3 1.1.1.4
ip nat inside source static 10.0.50.4 1.1.1.5
ip nat inside source static 10.0.50.5 1.1.1.6
ip nat inside source static 10.0.50.6 1.1.1.7
ip nat inside source static 10.0.50.7 1.1.1.8
ip nat inside source static 10.0.50.8 1.1.1.9
ip nat inside source static 10.0.50.9 1.1.1.10
ip nat inside source static 10.0.50.10 1.1.1.11
ip nat inside source static 10.0.50.11 1.1.1.12
ip classless
no ip http server
line vty 0 15
end
Kelvin Willacey Fri, 10/25/2013 - 19:24
Looks good, except why do you need this?
ip nat inside
no ip mroute-cache
And remember to point the default route to the next hop IP if you can.
Richard Burts Fri, 10/25/2013 - 19:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I like the individual DHCP scopes. I believe that your access list 1 and address translation will work ok. You still have a problem with your static default route specifying just the outbound interface. There are several negative aspects of doing it this was. You should change it to also specify the next hop IP address.
Rick
