10-25-2013 12:25 AM - edited 03-10-2019 09:01 PM
Hi there,
for migration purpose, is there a way to configure the ISE to use an existing NAC Guest User database for Guest authorization?
10-27-2013 12:32 AM
That should not be a problem however I have not tested this. When using the guest identity sequence in ISE you have the ability to add the databse you want to ISE to check. I do not see why you could not add another radius database to that selection. Here is a thread on configuring this -
https://supportforums.cisco.com/thread/2183727
Tarik Admani
*Please rate helpful posts*
10-29-2013 06:51 AM
