Warning message
Cisco ISE 1.2 keyboard number pad not working in CLI
Oct 25th, 2013
I cant get a keyboard number pad to work in ISE 1.2 when accesing via the SSH CLI.  NumLock makes no difference and changing settings in my Putty session doesnt make any difference either.
Anyone got any ideas?
Saurav Lodh Fri, 10/25/2013 - 02:53
  • Gold, 750 points or more
Can you try accessing  another device consoles just to confirm your terminal application is working fine and also the keyboard. You can also try rebooting ISE and re access its CLI.
Nicholas Poole Fri, 10/25/2013 - 07:16
Connection to a Cisco router CLI or even a Cisco ISE 1.1 CLI works fine from the same Putty client on the same machine.  ISE 1.2 has been rebooted several times and it is no different.
Tarik Admani Sun, 10/27/2013 - 00:19
  • Green, 3000 points or more
Have you tried to ssh into the router and then ssh into the ISE node? Are you running this on a vm or is this an appliance, by any chance is this the UCS appliance, try accessing the console port through CIMC if possible.
Tarik Admani
*Please rate helpful posts*
Nicholas Poole Mon, 10/28/2013 - 03:59
Hi Tarik.  Logged into 3750 and then onto ISE, no difference, screen flashes when i press a key on the number keypad.
This last test was on my lab VM, but I experience this on customers appliances too.
Related Content
