Warning message
CME Version 8.6 and cisco jabber
Answered Question
Oct 25th, 2013
We have a cme version 8.6 and we are wondering if we can configure a cisco jabber into our mobile phones
We have android platforms and iphone
Thank you
Correct Answer by Carlo Poggiarelli about 3 years 9 months ago
Hi.
Iphone is the only mobile phone supported by UC5XX because of the release of CME they run.
https://supportforums.cisco.com/docs/DOC-9827
CiscoMobile-iOS is the right device type
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Correct Answer by islam.kamal about 3 years 9 months ago
In addition to the professional configuration of Mr/Carlo , Please also find the below document which shows you that V8.6 support jabber + required configuration.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1058022
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1063949
Thank you
Please rate all useful information
Sure you can.
You have to define it as registrer pool.
Here you have an example.
voice register dn  1
number 2000
name Carlo-Jabber 2000
voice register pool  1
registration-timer max 720 min 660
id mac 1234.5678.0987
session-transport tcp
type Jabber-Android
number 1 dn 1
username carlo password cisco
codec g711ulaw
Carlo
Overall Rating: 5 (3 ratings)
Correct Answer
Carlo Poggiarelli Fri, 10/25/2013 - 05:31
  • Green, 3000 points or more
Sure you can.
voice register dn  1
number 2000
type Jabber-Android
number 1 dn 1
codec g711ulaw
Carlo
Correct Answer
islam.kamal Fri, 10/25/2013 - 06:14
  • Red, 2250 points or more
Thank you
lgrusila avain Fri, 10/25/2013 - 06:23
Carlo and Islam
Thank you so much
What about UC540 .Its the same philosophy as the above right?
What about if in the type : the cisco jabber is not available and is available only the CiscoMobile-iOS
We have to upgrade the ios  right?
Correct Answer
Carlo Poggiarelli Fri, 10/25/2013 - 06:37
Hi.
Carlo
Carlo Poggiarelli Fri, 10/25/2013 - 07:10
Hi.
For the roadmap I posted above, it seems so
Carlo
lgrusila avain Fri, 10/25/2013 - 07:18
Ok clear
From the config i dont see also any other device type for example sip device type for any other sip application
So assume that is not supported also any other sip application
islam.kamal Fri, 10/25/2013 - 07:24
For above configuration of type Jabber-Android.  Here we specify the sip client type. It can either be CiscoMobile-iOS for Apple iPhone users or Jabber-Android for Android users
Thank you
lgrusila avain Fri, 10/25/2013 - 07:41
iSLAM
Is available only the CiscoMobile-iOS for our device so for android is not any option
That is clear
What i am wondering if we could use other application than jabber with sip profile configuration
but as i see is not any option for sip device except teh default for jabber (either iphone or android)
islam.kamal Fri, 10/25/2013 - 07:49
ohhh , so under type there is no jabber-android. How can if you use CME v8.6 , this will not work if you assign sip application , should mention on type jabber-android.you can try , and i will search for you about files for jabber should be on your flash , to enable jabber-android.
Thank you
Please rate all useful infromation
islam.kamal Fri, 10/25/2013 - 07:53
I think jabber-android only availble on V9 , but i will search about v8.6
Thank you
