10-25-2013 05:48 AM - edited 03-10-2019 09:01 PM
Is is possible to repurpose our NAC Server and Manager 3310 equipment with ISE?
Solved! Go to Solution.
10-27-2013 12:20 AM
You can not repurpose the nac 3310, the 33x5 and the ACS 1121 are the supported platforms for ISE. However existing customers have benefits for upgrading to ISE. Please reach out to your Cisco partner and if you do not have on handy you can reach out to me and I can help.
Tarik Admani
*Please rate helpful posts*
10-27-2013 12:20 AM
Tarik Admani
