CUCM 9.1.2 Conferencing Issue
Oct 25th, 2013
I have a new deployment of Cisco BE6K where I have a CUCM Publisher and one subscriber. Also in the deployment are pub-sub of Unity Connection and Cisco IM&Presence. I have 2 cube routers one at each location of the CUCM server with a SIP trunk into each one. Version of CUCM is 9.1.2.10000-28. My problem is this: If I initiate a call from an IP phone to the PSTN (cell phone is what I've used) and then attempt to conference in another IP phone in the same device pool, same region, the conference connects the 2 IP phones and drops the PSTN call leg.
However on the flipside, if I call from the PSTN cell phone used before to the IP phone, then conference in another IP phone the conference will be completed. Any help on this is greatly appreciated. Phones are 8945s, Cubes are Cisco 2921, server is Cisco C220. Entire Cisco network.
Jaime Valencia Fri, 10/25/2013 - 22:15
  • Cisco Employee,
  • Hall of Fame,
    2011
What codecs are configured for the call legs in CUBE??
You might be hitting different dial-peers and codec configs for inbound and outbound calls.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Joe Christensen Sat, 10/26/2013 - 06:01
Here are my CUBE dial-peers and voice class.
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
dial-peer voice 2 voip
description INBOUND VOICE FROM CARRIER
session protocol sipv2
session target sip-server
incoming called-number ^[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip
description CUCM PUB VOICE
destination-pattern ^99999[2-9]..[2-9]......$
session target ipv4:192.168.9.211
incoming called-number 8T
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 4 voip
description CUCM SUB VOICE
preference 1
session target ipv4:192.168.10.211
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 100 voip
description OUTBOUND VOICE TO CARRIER INTL
destination-pattern ^8011T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 101 pots
preference 1
destination-pattern 8011T
port 0/0/0:23
prefix 011
dial-peer voice 110 voip
destination-pattern ^8[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 111 pots
preference 1
port 0/0/0:23
forward-digits 10
dial-peer voice 120 voip
description OUTBOUND VOICE TO CARRIER 911
destination-pattern ^8911$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 121 pots
preference 1
port 0/0/0:23
forward-digits 3
Joe Christensen Mon, 10/28/2013 - 07:41
We need to use G729 across the WAN and with the carrier. We have DSPs in the CUBE that should help with this. See below.
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 3 register YST-CFB1
associate profile 1 register YST-MTP1
associate profile 2 register YST-XCD1
signaling dscp af31
dspfarm profile 2 transcode
codec g729r8
codec g722-64
codec isac
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 20
associate application SCCP
dspfarm profile 1 mtp
codec pass-through
codec g729r8
maximum sessions software 300
dspfarm profile 3 conference video guaranteed-audio
codec g722-64
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec h264 cif
codec h264 vga
codec h264 4cif
maximum sessions 4
