mDNS cannot be configured when FlexConnect Local Switching is enabled
Answered Question
Oct 25th, 2013
I am running Cisco Prime Infrastructu tore 1.3 and I am trying to push a template to allow flexconect local switching on a wlan.  However, when I attempt this, I get the message "mDNS cannot be configured when FlexConnect Local Switching is enabled" and I cannot save the template or apply it to controllers.  My controllers are WISM 2s running 7.0.235.3.
Correct Answer by Jacob Snyder about 3 years 9 months ago
Make sure you uncheck the mDNS option on the advanced tab of the WLAN template. You cannot use mDNS in conjunction with Flexconnect locally switched WLANs.
Overall Rating: 5 (1 ratings)
Correct Answer
Jacob Snyder Sun, 10/27/2013 - 10:12
  • Bronze, 100 points or more
jlhainy Sun, 10/27/2013 - 15:34
hehehe.  I guess I should have scrolled down.  I couldn't see the setting.  I'm good.  thanks.
Trending Topics - Security & Network
