Warning message
RV220W PPTP Start IP Address must not be in the subnet of LAN:192.168.1.1/255.255.255.0
Oct 26th, 2013
I start setup of new RV220W Wireless router.
I want to provide access to internal network via PPTP.
But gettting error 'PPTP Start IP Address must not be in the subnet of LAN:192.168.1.1/255.255.255.0'.
I reviewed the forum and some user's says what they can fix this issue, but I cannot found the way how to do it.
Details of router:
Firmware Version
1.0.4.17
LAN (Local Network) Configuration
IP Address
(xxx.xxx.xxx.xxx)
Subnet Mask
(xxx.xxx.xxx.xxx)
DHCP
DHCP Mode
                                 None                                 DHCP Server                                 DHCP Relay
Domain Name
Starting IP Address
(xxx.xxx.xxx.xxx)
Ending IP Address
(xxx.xxx.xxx.xxx)
Primary DNS Server
(Optional)
Secondary DNS Server
(Optional)
Lease Time
Hours (Range : 1 - 262800, Default : 24)
Remote DHCP Server
LAN (Local Network) Proxy
DNS Proxy
Enable
VLANEnable
Create VLANs and assign the Outgoing Frame Type.
Up to Fifteen new VLANs can be created. VLAN IDs must be in the range (2 - 4093)
VLAN Membership Table
VLAN IDDescriptionInter VLAN RoutingDevice ManagementPort 1Port 2Port 3Port 4
1DefaultEnabledEnabledUntaggedUntaggedUntaggedUntagged
Multiple VLAN Subnet Table
VLAN IDIP AddressSubnet MaskDHCP ModeDNS Proxy Status
1192.168.1.1255.255.255.0DHCP ServerEnabled
VPN Users
PPTP Server Configuration
PPTP Server
Enable
Starting IP Address
(xxx.xxx.xxx.xxx)
Ending IP Address
(xxx.xxx.xxx.xxx)
VPN Client Setting Table
No.EnabledUsernamePasswordAllow User to Change PasswordProtocol
0 results found
All settings after reset to factory settings.
How I can enable assigning the IPs from LAN network to the PPTP Server?
Thank you!
alex_dotpromo Sun, 10/27/2013 - 03:43
Hm... Donwgrade of firmware to 1.0.3.5 fixed this issue. But why latest firmware so buggy?
kenziecampbell Tue, 03/25/2014 - 12:18
I have the same issue with firmware 1.0.5.8 – I'll try downgrading to 1.0.3.5. Thanks.
PPTP Start IP Address must not be in the subnet of LAN30:192.168.30.1/255.255.255.0
Kremena Ivanova Wed, 03/26/2014 - 05:44
  • Bronze, 100 points or more
This is a change done explicitely starting firmware 1.0.4.17. It is not a bug. This appears to be by design. PPTP peer networks are now treated as a routed subnet. It is unlikely that this will be changed.
But nevertheless there is a workaround to configure the PPTP range in the same subnet as your LAN:
1. Configure LAN IP subnet different from what you will use, for example 192.168.2.0/24
2. Configure DHCP pool for PPTP client as needed for example 192.168.1.100-192.168.1.110
3. Go back to LAN interface and change LAN IP to desired one: 192.168.1.0/24 and pool 192.168.1.2-192.168.1.99
4. This way there will be no error on GUI
5. PPTP client will receive IP address from the same subnet as LAN interface of the RV220W
Kremena
