2620Xm and a nm-2fe2w
Oct 27th, 2013
I am having difficulty getting these two to play nicely. My router has 128 memory and 32 flash. Thr card has a solid light until the ios finishes booting and then it dims. I have the 12.4T advanced enterprise ios. Exact IOS escapes me right now but all I should require is the 12.2(8)T IOS. On boot IOS reports an Unknown device. Show diag provides the card information and part number but lists the port disabled (216). Has any one gotten these devices to work together? If so, could you tell me the IOS that worked? Is there something special that has to be done for this card to be installed? Thank you very much!
andyurban1 Mon, 10/28/2013 - 03:30
I have the output of my router here, just to clarify it is the v1 and not the v2 of this module.
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
00036C          0X000B3B80 C2620XM Single Fast Ethernet
0000D8           UNKNOWN port adapter
                0X00098670 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X0035D1F0
Cisco IOS Software, C2600 Software (C2600-SPSERVICESK9-M), Version 12.4(15)T14
Cisco 2620XM (MPC860P) processor (revision 1.0) with 127627K/3445K bytes of memo
ry.
Processor board ID JAD07070TZU
M860 processor: part number 5, mask 2
1 FastEthernet interface
1 Serial interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Mar  1 00:00:09.915: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 216)) is no
t supported on this image.
           Please issue "show diag" in fully loaded IOS image
           to get the PA's information and verify if it is supported
           by this image, a newer version may be needed.
Slot 1:
        Unknown (type 216) Port adapter
        Port adapter is disabled
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-04797-01
        Board Revision           : F0
        Deviation Number         : 0-8707
        Fab Version              : 05
        PCB Serial Number        : JAD05310GPC
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : NM-2FE2W=
        EEPROM format version 4
andyurban1 Mon, 10/28/2013 - 04:01
I was reading this,
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet09186a00801aa71c.html
Looking at it seems like it would be compatible, Is table five only refering to the 2m? Do you have any recommendation on how to get an additional FastEthernet port? I am studying for my CCNA and would like to get connectivity to my Cable internet. I actually have 2 2620XM's thank you!
johnlloyd_13 Mon, 10/28/2013 - 04:38
  • Blue, 1500 points or more
It looks like there might be some inconsistencies in the docs. Did you try to install it on the other router and was able to detect it?
Otherwise you can opt for an NM-1E. Was recently browsing through the 2600XM series and I always go for at least 2 FE ports. I'm eyeing for an 2651XM for a FR switch or terminal server.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet...
Related Content
