Warning message
ASR903 - SONET encapsulation problems
Oct 28th, 2013
Hello all,
I want to configure encapsulation frame-relay over OC3 interface (A900-IMA4OS):
controller sonet 0/4/0
framing sdh
aug mapping aug-4
au-4 1 tug-3 1
tug-2 1 e1 1 unframed
tug-2 1 e1 2 unframed
tug-2 1 e1 3 unframed
tug-2 2 e1 1 unframed
tug-2 2 e1 2 unframed
interface Serial0/4/0.1/1/1/3:0
bandwidth 2048
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
frame-relay intf-type dci
I'm running IOS-XE 03.09.01a.S (15.3(2)S1a).
When I introduce the "encapsulation frame-relay" command, ASR903 is reloaded.
I've been looking for information regarding this problem but I haven't found anything about bugs.
By other hand, I've seen one limitation for optical interfaces in ASR903 on release 3.9.x:
Limitations and Restrictions
The following limitations and restrictions apply when configuring optical interface modules on the Cisco ASR 903 Router:
SDH framing mode is supported; SONET framing is supported beginning in Release 3.8.
HDLC, PPP, and MLPPP encapsulation are supported. In POS mode, HDLC and PPP are supported.
Frame Relay and SMDS encapsulation are not supported.
However, IOS is showing this encapsulation in order to use it:
MPLS-PE-AME-01(config-if)#encapsulation ?
  frame-relay  Frame Relay networks
  hdlc         Serial HDLC synchronous
  ppp          Point-to-Point protocol
  smds         Switched Megabit Data Service (SMDS)
Now, I'm doubt whether this is a bug or a limitation.
Best regards,
Alfonso Moneo
vmiller Mon, 10/28/2013 - 09:53
  • Gold, 750 points or more
I could find nothing to indicate that frame relay encapsulation is supported on this module:
"The Cisco ASR 900 multiservice interface modules are designed to help customers connect to legacy networks and transition to packet networks. The multiservice interface modules support connections to Point-to-Point Protocol (PPP), Multilink PPP, ATM, Inverse Multiplexing over ATM (IMA) and High-Level Data Link Control (HDLC) links.  "
ALFONSO MONEO V... Wed, 11/06/2013 - 05:22
vmiller, thanks a lot for your response. I think it's simply a bug. IOS-XE 03.10 don't already support encapsulation frame-relay command.
Best Regards,
Alfonso Moneo
sanjees4 Fri, 12/04/2015 - 03:12
we are using A900-IMA4OS for the first time .Can anyone tell me the operation command ( to check number of interface /port status /optical power / KLM status/ how to give loop ) or is there any document on the same please share link .
