Warning message
Add in VOIP network in Site to Site VPN (ASA 5510)
Answered Question
Oct 29th, 2013
I need some help. I have 2 offices (1 in viet and 1 in singapore). These 2 offices already have site to site vpn setup. However, when i try to add in the VOIP network (172.28.200.0/24) into the site to site vpn. I am still unable to reach my call manager from viet office.
See below picture for the site to site VPN network. Same setting for viet asa except the local n/w would be 172.29.52.0/22.
THanks in advance!
Correct Answer by Jouni Forss about 3 years 9 months ago
Would really need to see configurations from the ASA or some other output to determine what the problem is
The most common problems would be that the Crypto ACL are compatible with eachother on the sites. One problem could also be that you are lacking the NAT0 / NAT Exempt configuration for this network on both sites.
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Tue, 10/29/2013 - 01:22
- Jouni
hokokshun Tue, 10/29/2013 - 01:48
Hi Jouni,
Thanks thanks! it is the NAT Exempt which i missed out!. THANKS A LOT!
