Warning message
VIC-4FXS/DID - no dial tone
Oct 29th, 2013
Running -  :c2800nm-advipservicesk9-mz.151-4.M4.bin
Show voice-port summary
0/2/0           --  fxs-ls      up    up   off-hook idle     y
0/2/1           --  fxs-ls      up    up   off-hook idle     y
0/2/2           --  fxs-ls      up    up   off-hook idle     y
0/2/3           --  fxs-ls      up    up   off-hook idle     y
show voice-call summary
0/2/0         -          -  -                     FXSLS_PARK
0/2/1         -          -  -                     FXSLS_PARK
0/2/2         -          -  -                     FXSLS_PARK
0/2/3         -          -  -                     FXSLS_PARK
when I - shut and no shut a port I see  - 9 of these messages ..
Oct 29 15:54:43.154 : Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
I have disconnected all the cables from the card and tried just one port with a POTS handset - no joy
Cant make or recieve calls.
Please note there is a card is slot 3 - VIC2-2FXS - this is working perfectly.
Any ideas ??
James
Overall Rating: 1 (1 ratings)
Jorge Armijo Tue, 10/29/2013 - 07:10
  • Silver, 250 points or more
Please post the following information:
-show run
-show version
-show diag
-show voice dsp group all
-show voice dsp detail
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
keanej Tue, 10/29/2013 - 07:23
Show Diag :
        WIC Slot 2:
        FXS Voice daughter card (4 port)
        Hardware Revision        : 3.1
        Part Number              : 73-6918-02
        Board Revision           : F0
        Deviation Number         : 0
        Fab Version              : 02
        PCB Serial Number        : FOC13223SDG
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Top Assy. Part Number    : 800-17016-02
        Connector Type           : 01
        CLEI Code                : IP9IABYCAA
        Product (FRU) Number     : VIC-4FXS/DID=
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 00 3A 41 03 01 82 49 1B 06 02 42 46 30
          0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 33 32 32
          0x20: 33 53 44 47 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 42 78 02 05 01 C6 8A 49 50 39 49 41 42 59
          0x40: 43 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 28.3.5
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 0
    Credits used (rounded-up): 0
dsp 2:
  Max credits: 240
dsp 3:
  Max credits: 240
dsp 4:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
    Signaling channels allocated: 0
dsp 5:
  Max credits: 240
dsp 6:
  Max credits: 240
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 30
    Codec: CONF_G711, maximum participants: 8
    Sessions per dsp: 8
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
  0 DSP resource allocation failure
show voice dsp detailed
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
edsp 0001 01 g711ulaw  0.1 IDLE  50/0/11.1
edsp 0002 02 g729r8 p  0.1 IDLE  50/0/11.2
edsp 0003 01 g711ulaw  0.1 IDLE  50/0/12.1
edsp 0004 02 g729r8 p  0.1 IDLE  50/0/12.2
edsp 0005 01 g711ulaw  0.1 IDLE  50/0/13.1
edsp 0006 02 g729r8 p  0.1 IDLE  50/0/13.2
edsp 0007 01 g711ulaw  0.1 IDLE  50/0/14.1
edsp 0008 02 g729r8 p  0.1 IDLE  50/0/14.2
edsp 0009 01 g711ulaw  0.1 IDLE  50/0/15.1
edsp 0010 02 g711ulaw  0.1 IDLE  50/0/15.2
edsp 0011 01 g729r8 p  0.1 IDLE  50/0/16.1
edsp 0012 02 g729r8 p  0.1 IDLE  50/0/16.2
edsp 0013 01 g711ulaw  0.1 IDLE  50/0/20.1
edsp 0014 02 g729r8 p  0.1 IDLE  50/0/20.2
edsp 0015 01 g729r8 p  0.1 IDLE  50/0/21.1
edsp 0016 02 g729r8 p  0.1 IDLE  50/0/21.2
edsp 0017 01 g729r8 p  0.1 IDLE  50/0/30.1
edsp 0018 01 g729r8 p  0.1 IDLE  50/0/31.1
edsp 0019 01 g729r8 p  0.1 IDLE  50/0/32.1
edsp 0020 01 g729r8 p  0.1 IDLE  50/0/33.1
edsp 0021 02 g729r8 p  0.1 IDLE  50/0/33.2
edsp 0022 01 g729r8 p  0.1 IDLE  50/0/34.1
edsp 0023 02 g729r8 p  0.1 IDLE  50/0/34.2
edsp 0024 01 g729r8 p  0.1 IDLE  50/0/35.1
edsp 0025 02 g729r8 p  0.1 IDLE  50/0/35.2
edsp 0026 01 g729r8 p  0.1 IDLE  50/0/36.1
edsp 0027 02 g729r8 p  0.1 IDLE  50/0/36.2
edsp 0028 01 g729r8 p  0.1 IDLE  50/0/38.1
edsp 0029 01 g729r8 p  0.1 IDLE  50/0/39.1
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510  001 01 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 02 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 03 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 04 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 05 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 06 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 07 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 08 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 09 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 10 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 11 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 12 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 13 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 14 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 15 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  001 16 None          28.3.5 idle  idle      1  1                 0          0/0
C5510  002 01 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 02 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 03 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 04 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 05 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 06 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 07 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 08 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 09 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 10 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 11 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 12 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 13 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 14 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 15 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  002 16 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 01 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 02 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 03 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 04 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 05 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 06 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 07 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 08 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 09 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 10 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 11 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 12 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 13 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 14 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 15 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  003 16 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 01 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 02 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 03 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 04 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 05 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 06 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 07 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 08 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 09 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 10 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 11 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 12 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 13 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 14 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 15 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  004 16 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 01 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 02 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 03 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 04 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 05 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 06 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 07 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 08 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 09 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 10 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 11 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 12 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 13 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 14 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 15 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  005 16 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 01 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 02 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 03 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 04 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 05 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 06 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 07 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 08 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 09 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 10 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 11 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 12 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 13 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 14 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 15 None          28.3.5 idle  idle      0  0                 0          0/0
C5510  006 16 None          28.3.5 idle  idle      0  0                 0          0/0
                           *DSP SIGNALING CHANNELS*
C5510  001 01 {flex}        28.3.5 alloc idle      1  1 0/2/1     06    0         49/0
C5510  001 02 {flex}        28.3.5 alloc idle      1  1 0/2/0     06    0        131/0
C5510  001 03 {flex}        28.3.5 alloc idle      1  1 0/2/3     02    0         69/0
C5510  001 04 {flex}        28.3.5 alloc idle      1  1 0/2/2     02    0         53/0
C5510  001 05 {flex}        28.3.5 alloc idle      1  1 0/3/0     02    0         58/0
C5510  001 06 {flex}        28.3.5 alloc idle      1  1 0/3/1     02    0         53/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Some Running Config
network-clock-participate wic 0
network-clock-participate wic 1
isdn switch-type primary-net5
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
  h225 timeout setup 2
  call start slow
voice class codec 353
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g728
codec preference 4 g711alaw
codec preference 5 g711ulaw
codec preference 6 g726r32
codec preference 7 g726r24
codec preference 8 g726r16
codec preference 9 g723r63
codec preference 10 g723ar63
voice class h323 353
voice-card 0
dspfarm
dsp services dspfarm
voice-port 0/0/0:15
voice-port 0/1/0:15
voice-port 0/2/0
no vad
no comfort-noise
cptone RU
caller-id enable
voice-port 0/2/1
no vad
no comfort-noise
caller-id enable
voice-port 0/2/2
no vad
no comfort-noise
caller-id enable
voice-port 0/2/3
no vad
no comfort-noise
caller-id enable
voice-port 0/3/0
no vad
no comfort-noise
caller-id enable
voice-port 0/3/1
no vad
no comfort-noise
caller-id enable
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp profile default
sccp local FastEthernet0/1
sccp ccm 10.82.10.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODER
associate profile 2 register XCONFERENCE
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 1
associate application SCCP
shutdown
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
maximum sessions 1
dial-peer voice XXXXXX2 pots
destination-pattern XX2
fax rate disable
port 0/2/0
dial-peer voice XXXXXX3 pots
destination-pattern XX3
fax rate disable
port 0/2/1
dial-peer voice XXXXXX4 pots
destination-pattern XX4
fax rate disable
port 0/2/2
dial-peer voice XXXXXX5 pots
destination-pattern XX5
fax rate disable
port 0/2/3
dial-peer voice XXXXXX6 pots
destination-pattern XX6
fax rate disable
port 0/3/0
dial-peer voice XXXXXX7 pots
destination-pattern XX7
fax rate disable
port 0/3/1
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 2
sdspfarm unregister force
sdspfarm tag 1 XCODER
sdspfarm tag 2 XCONFERENCE
conference hardware
voice service voip
h323
  call start slow
voice-card 0
dspfarm
voice-port 0/0/0:15
voice-port 0/1/0:15
voice-port 0/2/0
no vad
no comfort-noise
cptone RU
caller-id enable
voice-port 0/2/1
no vad
no comfort-noise
caller-id enable
voice-port 0/2/2
no vad
no comfort-noise
caller-id enable
voice-port 0/2/3
no vad
no comfort-noise
caller-id enable
voice-port 0/3/0
no vad
no comfort-noise
caller-id enable
voice-port 0/3/1
no vad
no comfort-noise
caller-id enable
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 1
shutdown
codec g711ulaw
codec g711alaw
maximum sessions 1
fax rate disable
port 0/2/0
fax rate disable
port 0/2/1
fax rate disable
port 0/2/2
fax rate disable
port 0/2/3
fax rate disable
port 0/3/0
fax rate disable
port 0/3/1
telephony-service
sdspfarm units 2
conference hardware
If you need anymore info - let me know
Jorge Armijo Tue, 10/29/2013 - 07:42
Did you try a reseat of the card?
Jorge Armijo
Aman Soi Tue, 10/29/2013 - 21:27
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi James,
When u connect Analog Handset on the either of the FXS ports of card, does any LED glow on card.
regds,
aman
keanej Mon, 11/11/2013 - 02:16
Jorge,
You ask for all the configs ..
and then ask - did you reseat the card - thats not helpful at all.
Last time I post my config on here !
I am in the process of replacing the card.
keanej Mon, 11/18/2013 - 03:23
Guys,
Just to let you know the solution here. I replaced the card with a new VIC3-4FXS card - the new card worked fine.
So this was a hardware fault.
James
Aman Soi Mon, 11/18/2013 - 06:29
    2017 IP Telephony
thanks for update.
regds,
aman
