Warning message
3750 switch stacking configuration
Oct 29th, 2013
Hello All,
I am new to networking and I am trying to learn switch stacking. I am having following issues.
(Both switches are compatible to each other).
  • "show switch stack-ports summary" command showed the port status as "absent" (indicating no cable detected on stack port though screws are tightened propperly)
Switch-2A#show switch stack-ports summary
Switch#/ Stack Neighbor Cable Link Link Sync # In
Port# Port Length OK Active OK Changes Loopback
Status To LinkOK
1/1 Absent None No cable No No No 0 Yes
  • "show switch" command only detects "master", not the slave or the member
Switch-2A#show switch detail
Switch/Stack Mac Address : e8b7.4843.1f00
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master e8b7.4843.1f00 1 1 Ready
Help me to find out what is going wrong in the configuration.
Thank You,
Archana
JohnTylerPearce Tue, 10/29/2013 - 12:40
  • Silver, 250 points or more
How are the stack cables configured? Also, can you post the configuration for your stack configuration?
Korimarchana Tue, 10/29/2013 - 18:19
Thanks for your response.
It worked after changing the cable.
