Warning message
Error: sticky resource not available
Answered Question
Oct 30th, 2013
I get the following error when I try to add sticky config to a context.
I have added the following to the admin context but no joy:
resource-class **********
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum equal-to-min
One thing I noticed is it is only on the admin context of one ace module. It ain't on the admin module of the other ace context. Do I need to add it manly to both? Afraid of putting them out of sync.
Can anyone please advise?
Correct Answer by Fnu Kanwaljeet Singh about 3 years 9 months ago
So you can create resource class and assign to the context you are having issues with. You can look through the user guide for better understanding of how resource allocation works.
Kanwal
Hi Netter,
You can use ,
show running-config resource-class
show resource-allocation
The above two commands shall show the details.
Kanwal
Hi Netter,
You should what is the current resoruce allocation for your context and see what is changing. There should be no problem as long as you are increasing the resource.
Kanwal
Overall Rating: 5 (3 ratings)
netternewbie Wed, 10/30/2013 - 10:28
I just added it on the other ACE admin context manually and still no joy.
Can anyone tell me what I need to do to get stickiness working?
Fnu Kanwaljeet Singh Wed, 10/30/2013 - 11:08
  • Cisco Employee,
Hi Netter,
You have defined the resource class and defined the limits but did you associate with the respective "Contexts"? Without association with any context it is just a resource class!
Please associate if you haven't already and let me know if you still face the same problem.
Kanwal
netternewbie Wed, 10/30/2013 - 11:22
Hi Kanwal,
Thanks for your response. I am new to this and taking over from someone else. Can you tell me how you associate it with a particular context? Is it in the context itself? Whats the command?
Many thanks
Fnu Kanwaljeet Singh Wed, 10/30/2013 - 11:25
  • Cisco Employee,
Hi Netter,
Here is the configuration that you need to do in "Admin" context. So i created a class (like you did above) named as "Test1". After that i go to context "Kan" and made it member of resource class Test1.
switch/Admin(config)# context Kan
switch/Admin(config-context)# member Test
Test   Test1
switch/Admin(config-context)# member Test1
switch/Admin(config-context)# exit
Let me know how it works and if this resolves your problem.
Kanwal
netternewbie Wed, 10/30/2013 - 11:33
Thanks Kanwal,
I will give this a go. There are other services live already in this context. Will this cause any issues? Presume I just do it in active context?
Thanks.
Correct Answer
Fnu Kanwaljeet Singh Wed, 10/30/2013 - 11:35
  • Cisco Employee,
Hi Netter,
Kanwal
netternewbie Wed, 10/30/2013 - 11:44
Thanks Kanwal,
Another stupid question but how do I check current resource allocation? There was nothing in admin or its context until I greated class above. So presume its default resources?
Thanks.
Correct Answer
Fnu Kanwaljeet Singh Wed, 10/30/2013 - 12:06
  • Cisco Employee,
Hi Netter,
You can use ,
Kanwal
netternewbie Wed, 10/30/2013 - 12:19
Thanks Kanwal,
I did this in the admin context and it has no resources assigned to it.
Correct Answer
Fnu Kanwaljeet Singh Wed, 10/30/2013 - 13:00
  • Cisco Employee,
Kanwal
netternewbie Wed, 10/30/2013 - 15:10
Thanks, yes will do this and let you know how it goes tomorrow.
netternewbie Thu, 10/31/2013 - 04:37
Thanks Kanwal, this did the trick and I can apply stickness now. Unfortunately it didn't fix my main problem. Load balancing 2 web servers with redirest on port 80 to 443. But I get the following error:
This webpage has a redirect loop
Can open a separate discussion on this if you like. Config is fairly basic. Not sure what is wrong. If its me or the server guys. Any thoughts?
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 06:05
  • Cisco Employee,
Hi Netter,
Send me the configuration and i will have a look. 80 t0 443 should be a simple redirection. Who is doing the redirection here, ace or webserver?
Kanwal
netternewbie Thu, 10/31/2013 - 06:16
Hi Kanwal,
Should be ace but think server guys have a redirect as well. Will get them to turn off. Just heading to a meeting now. Will try and get a config onto you in the next hr. Thanks again.
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 06:19
  • Cisco Employee,
Hi Netter,
My pleasure in assisting you. Get me the configuration and we will see what is going on here.
Kanwal
netternewbie Thu, 10/31/2013 - 07:35
Thanks Kanwal. Here is the current config. I think I am on right track.
crypto chaingroup ****-CHAINGRP
  cert chain-ROOT
    cert ****CAcert
crypto csr-params CSR-PARAMS
  country
  state
  locality
  organization-name
  organization-unit
  common-name ****.co.uk
  serial-number 601
access-list BPDU ethertype permit bpdu
probe tcp ****-WEB-PROBE
  interval 3
  passdetect interval 5
parameter-map type ssl SSL-****-ADVANCED
  cipher RSA_WITH_RC4_128_MD5
rserver host ****TC1
  ip address *.*.*.*
  inservice
rserver host ****TC2
  ip address *.*.*.*
  inservice
rserver redirect HTTP-****
  webhost-redirection https://%h/%p 301
  inservice
ssl-proxy service SSL-****-PROXY
  key ****.pem
  cert ****CAcert
  ssl advanced-options SSL-****-ADVANCED
serverfarm host ****-FARM
  predictor leastconns
  probe ****-WEB-PROBE
  rserver ****TC1 80
    inservice
  rserver ****TC2 80
    inservice
serverfarm redirect HTTP-****-FARM
  rserver HTTP-****
    inservice
sticky ip-netmask 255.255.255.255 address source STICKY-SSL-****-FARM
  timeout 720
  timeout activeconns
  replicate sticky
  serverfarm ****-FARM
class-map match-any ****-HTTPS-VIP
  2 match virtual-address *.*.*.* tcp eq https
class-map match-any REDIRECT-HTTP-****
  2 match virtual-address *.*.*.* tcp eq www
policy-map type loadbalance first-match ****-HTTPS-POLICY
  class class-default
    sticky-serverfarm STICKY-SSL-****-FARM
policy-map type loadbalance first-match ****-POLICY-REDIRECT
  class class-default
    serverfarm HTTP-****-FARM
policy-map multi-match ****-POLICY
  class ****-HTTPS-VIP
    loadbalance vip inservice
    loadbalance policy ****-HTTPS-POLICY
    loadbalance vip icmp-reply active
    ssl-proxy server SSL-****-PROXY
policy-map multi-match ****REDIRECTPOLICY
  class REDIRECT-HTTP-****
    loadbalance policy ****-POLICY-REDIRECT
    loadbalance vip advertise
service-policy input ****REDIRECTPOLICY
service-policy input ****-POLICY
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 07:56
  • Cisco Employee,
Hi Netter,
The configuration looks absolutely fine to me.
So this configuratio didn't work? You said there was redirection loop which  i assume could happen because client didn't come with https url to which it was redirected otherwise it would have matched a different class and loadbalanced to different serverfarm.
Can you capture on client itself and see what URL client goes with after it has been redirected? That should tell us why the redirection is happening again and again.
You can also install iehttp for IE or Live utility in Mozilla to see the HTTP based communication between client and server(ACE).
And you don't need to define two policy mutli-match. You can simply call both class maps under the same policy mutli match. If it doesn't match the first class, it will look into second and so on. Once a match is done it stops.
Kanwal
netternewbie Thu, 10/31/2013 - 08:20
Hi Kanwal,
Just got word from the server guys  server runs on 8443. Do I just change
  rserver ****TC1 80
    inservice
  rserver ****TC2 80
to
  rserver ****TC1 8443
    inservice
  rserver ****TC2 8443
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 08:25
  • Cisco Employee,
Hi Netter,
If the server is listening on 8443 then backend connection would be SSL too which means you need to do end to end ssl loadbalancing or you can simply loadbalance based on TCP port and if you do so you need to remove SSL proxy configuration.
For end to end ssl you have to configure ACE both as ssl server and client and configuration will need a slight change. Please go through the below link for same.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_1_0/configuration/ssl/guide/endtoend.html
Let me know if have any questions.
Kanwal
netternewbie Thu, 10/31/2013 - 08:48
Thanks Kanwal,
To be honest I am knew to all this so haven't a clue which is best way to proceed. What way would you think is best? Would it be hard to change my current config to do end to end loadbalancing? Not sure where to start.
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 09:01
  • Cisco Employee,
    Hi Netter,
    To configure end-to-end SSL you need to make couple of changes and they are not big. Please go through the link and it will give you an idea of what you are missing.
Regarding what you should is absolutely your decision. Normally SSL offloading is done on ACE to relieve servers of cpu intensive SSL handshake which may impact their performance and also take decisions on the basis of data which ACE otherwise cannot see if it is not doing SSL ofloading.
In end to end ssl even backend connection is encrypted which means that you don't care about performance impact but you may still need ACE to look into data for LB decisions. If you don't need that you can simply tell ACE to LB on the basis of TCP port and connection would be encrypted from client to server and ACE would just do LB.
Honestly, it is your decision based on your requirement. If you don't want ACE to do anything by looking into decrypted packet then i would suggest go for TCP port based load balancing.but still your decision.
You can also go through the link for more details regarding end to end ssl which explains in detail about it.
If you have any questions please let me know.
Kanwal
netternewbie Thu, 10/31/2013 - 09:08
Thanks Kanwal,
The service has to run on 8443 if they disable redirects so guess I have to do end-to-end SSL. I will give it a go and let you know how I get on.
I don't think I can do it on tcp port as client may connect on 80 or 443 from a web browser.
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 09:20
  • Cisco Employee,
Hi Netter,
You are welcome. It is your choice as i said. But you can use redirection for port 80 and normal LB for 443 or end to end ssl. For end to end ssl you just need to make a minor change which you can see in the link i pasted. You have to add ssl-proxy client statement under policy-map type first match.
Let me know if you have any questions.
Kanwal
netternewbie Thu, 10/31/2013 - 09:43
Thanks Kanwal,
Doing that now. I am worried do I need to do this part.
interface vlan 210
ip address 10.10.2.1 255.255.255.0
  service-policy input L7_1
  access-group input ACL
  no shutdown
Do I need to add
service-policy input L7_1? There are servers already live in this context and I am afraid this will break them.
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 09:47
  • Cisco Employee,
Hi Netter,
I am not sure what this policy is. If the connections  already working don't match what this service policy (class map conditions) has then there should be no problems.
You can do this without breaking any existing connections. If you are not sure you can try this in off time.
Kanwal
netternewbie Thu, 10/31/2013 - 09:51
Sorry thats just from the config in link you sent me. I will send what I have done now. I think I am totally lost to be honest.
netternewbie Thu, 10/31/2013 - 10:22
Hi Kanwal,
Here is my current config. Is it totally wrong? Policy map L7_1 appears as offline.
cert chain-ROOT
  cert ****CAcert
access-list ALL line 8 extended permit ip any any
access-list ALL line 16 extended permit icmp any any
port 8443
interval 3
parameter-map type ssl PM1
session-cache timeout 300
queue-delay timeout 1
ip address *.*.*.*
inservice
ip address *.*.*.78
inservice
inservice
key ****.pem
cert ****CAcert
ssl-proxy service SSL_CLIENT
ssl advanced-options PM1
ssl-proxy service SSL_SERVER
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
class-map type http loadbalance match-any SSL
2 match http url .*
class-map match-any SSL_C1
3 match virtual-address *.*.*.* tcp any
class class-default
class class-default
policy-map type loadbalance first-match SSL_BACK
class SSL
ssl-proxy client SSL_CLIENT
policy-map multi-match L7_1
class SSL_C1
loadbalance policy SSL_BACK
ssl-proxy server SSL_SERVER
interface vlan 303
bridge-group 303
no normalization
mac-sticky enable
access-group input BPDU
access-group input ALL
no shutdown
interface vlan 603
bridge-group 303
no normalization
mac-sticky enable
no shutdown
interface bvi 303
ip address *.*.*.* 255.255.254.0
peer ip address *.*.*.* 255.255.254.0
no shutdown
ip route 0.0.0.0 0.0.0.0 *.*.*.1
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 10:55
  • Cisco Employee,
Hi Netter,
As per your requirement which i have understood after our discussion, you don't need to do any major. Please see the bold lines that you need to add and you should have end to end ssl configuration.
cert chain-ROOT
cert ****CAcert
country
state
locality
organization-name
organization-unit
serial-number 601
interval 3
ip address *.*.*.*
inservice
ip address *.*.*.*
inservice
inservice
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
class class-default
class class-default
Let me know how it goes.
Kanwal
netternewbie Thu, 10/31/2013 - 10:57
Thanks a million for all your help. I'll give this a go tomorrow and let you know how it goes.
netternewbie Thu, 10/31/2013 - 16:26
Thanks Kanwal,
Looks like it's getting closer but still not there. If I type service name it redirects to https:// but gives a no data received error on web page.
If I go directly to each server on https://*.*.*.*:8443 it works. Am I missing somthing simple. Here is a few show commands:
sh probe ****-WEB-PROBE
probe       : ****-WEB-PROBE
type        : TCP
state       : ACTIVE
   port      : 8443    address     : 0.0.0.0         addr type  : -
   interval  : 3       pass intvl  : 5               pass count : 3
   fail count: 3       recv timeout: 10
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : ****-FARM
     real      : ****TC1[8443]
                       *.*.*.*    7834       127        7707       SUCCESS
     real      : ****TC2[8443]
                       *.*.*.*    7836       128        7708       SUCCESS
sh serverfarm ****-FARM
serverfarm     : ****-FARM, type: HOST
total rservers : 2
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver:****TC1
       *.*.*.*:8443     8      OPERATIONAL  0          0          44
   rserver: *TC2
       *.*.*.*:8443     8      OPERATIONAL  0          0          0
sh service-policy
Policy-map : ****-POLICY
Status     : ACTIVE
Context Global Policy:
  service-policy: ****-POLICY
    class: ****-HTTPS-VIP
      ssl-proxy server: SSL-****-PROXY
      loadbalance:
        L7 loadbalance policy: ****-HTTPS-POLICY
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        curr conns       : 0         , hit count        : 363
        dropped conns    : 184
        client pkt count : 4051      , client byte count: 1056853
        server pkt count : 1765      , server byte count: 258936
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
    class: REDIRECT-HTTP-****
      loadbalance:
        L7 loadbalance policy: ****-POLICY-REDIRECT
        VIP Route Advertise  : ENABLED
        curr conns       : 0         , hit count        : 2
        dropped conns    : 0
        client pkt count : 8         , client byte count: 344
        server pkt count : 0         , server byte count: 0
netternewbie Thu, 10/31/2013 - 16:36
Also here is the current config. Maybe I am missing something or extra still in config.
  cert chain-ROOT
  cert ****CAcert
  port 8443
  interval 3
  ip address *.*.*.*
  inservice
  ip address *.*.*.*
  inservice
  inservice
  key ****.pem
  cert ****CAcert
    inservice
    inservice
  rserver HTTP-****
    inservice
  timeout 720
  timeout activeconns
  replicate sticky
  class class-default
  class class-default
Fnu Kanwaljeet Singh Thu, 10/31/2013 - 18:46
  • Cisco Employee,
Hi Netter,
My apologies but i was not entirely right. For end to end ssl it a requirment that you create a layer 7 class map. So you would need to make changes to the configuration. Let me paste one example for you:
class-map type http loadbalance match-all SSLCLASS
  2 match http url .*
Then you need to call this class under policy map.
Class SSLCLASS
Stikcy serverfarm STICKY-SSL-****-FARM
class class-default
Other than that it is looking fine.
Please try and let me know how it goes.
I tested with 443 backend and it worked. Couldn't test with backend 8443. But i think it should work fine.
Kanwal
netternewbie Fri, 11/01/2013 - 02:59
Hi Kanwal,
No joy unfortunately. This is what I have changed,
  class SSLCLASS
  class class-default
  class class-default
total rservers : 2
   rserver: ****TC1
       *.*.*.*:8443     8      OPERATIONAL  0          0          88
   rserver: ****TC2
       *.*.*.*:8443     8      OPERATIONAL  0          0          5
Fnu Kanwaljeet Singh Fri, 11/01/2013 - 05:50
  • Cisco Employee,
                   Hi Netter,
You didn't configure the L7 class map. Can you configure the L7 class map as shown in config i pasted in last post and see how it goes.
Kanwal
netternewbie Fri, 11/01/2013 - 06:24
Sorry Kanwal, I had it in. Here are the classes I have:
  2 match http url .*
Thanks again for your thorough help on this.
netternewbie Fri, 11/01/2013 - 07:31
Hi Kanwal, This is actually the full config I have now. Does it look ok to you?
cert chain-ROOT
cert ****CAcert
port 8443
interval 3
ip address *.*.*.*
inservice
ip address *.*.*.*
inservice
inservice
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
2 match http url .*
class SSLCLASS
class class-default
class class-default
netternewbie Fri, 11/01/2013 - 07:52
Thanks Kanwal. I now get this error though:
The connection was reset
The connection to the server was reset while the page was loading.
   *   The site could be temporarily unavailable or too busy. Try again in a few
          moments.
    *   If you are unable to load any pages, check your computer's network
          connection.
    *   If your computer or network is protected by a firewall or proxy, make sure
          that Firefox is permitted to access the Web.
I there anything else I can do? Do you think there is something still wrong with my config? I am really stuck now.
Thanks Again,
Fnu Kanwaljeet Singh Fri, 11/01/2013 - 07:56
  • Cisco Employee,
Hi Netter,
The config looks fine.
Send me the below output:
show service-policy detail.
Ensure that you don't need NAT. What is your serve's default gateway?
Is routing proper?
Kanwal
netternewbie Fri, 11/01/2013 - 08:04
Thanks Kanwal, here is the output. We use public addresses so I don't think I need NAT. We have another service running in this context and it is fine. The default gateway of servers with be gateway of Van: *.*.*.1.
sh service-policy ****-POLICY detail
Status     : ACTIVE
Description: -----------------------------------------
     VIP Address:    Protocol:  Port:
     193.1.174.104   tcp        eq    443
      loadbalance:
        Regex dnld status    : SUCCESSFUL
        curr conns       : 0         , hit count        : 467
        dropped conns    : 282
        client pkt count : 5054      , client byte count: 1206294
        server pkt count : 2068      , server byte count: 272134
        L7 Loadbalance policy : ****-HTTPS-POLICY
          class/match : SSLCLASS
            ssl-proxy client : SSL_CLIENT
             LB action: :
               sticky group: STICKY-SSL-****-FARM
                  primary serverfarm: ****-FARM
                    state: UP
                  backup serverfarm : -
            hit count        : 82
            dropped conns    : 0
          class/match : class-default
             LB action: :
                    state: UP
            hit count        : 0
            dropped conns    : 0
     *.*.*.*   tcp        eq    80
      loadbalance:
        curr conns       : 0         , hit count        : 24
        dropped conns    : 0
        client pkt count : 99        , client byte count: 7933
        L7 Loadbalance policy : ****-POLICY-REDIRECT
            LB action: :
               primary serverfarm: HTTP-****-FARM
                    state: UP
            hit count        : 6
            dropped conns    : 0
netternewbie Fri, 11/01/2013 - 08:08
Hi Kanwal, the VIP is actually a different subnet to servers so maybe this is the problem. I will change the IP of the VIP and change it in the context and see if it makes any difference.
Fnu Kanwaljeet Singh Fri, 11/01/2013 - 08:15
  • Cisco Employee,
                   Hi Netter,
We are getting hits on the policy as well as on sslclass but there are drops on L3 policy map.Can you also remove SSL parameter map from both ssl client proxy as well as server and give it a try.
VIP can be different as long as there is a route to it from uplink. Once traffic matches it will be loadbalanced to servers in serverfarm. Now servers should be able to send the traffic back (if ace is their GW or servers have a route towards ace or you do NAT so that traffic comes back  to ACE).
When you establish a connection what do you see in "show conn"? You can filter using your testing client IP address or VIP. So you can use show conn . Send me that output as well.
Also, ensure that policy is applied to the correct interface vlan. It should be applied to client facing VLAN.
Kanwal
netternewbie Fri, 11/01/2013 - 08:26
Sorry Kanwal, how or what do I remove. Is it like line bolded below:
ssl-proxy service SSL-FILR-PROXY
  key filr.pem
  cert filrCAcert
  chaingroup FILR-CHAINGRP
NO  ssl advanced-options SSL-FILR-ADVANCED
netternewbie Fri, 11/01/2013 - 08:38
Hi Kanwal,
Seem to have lost connection since makes those changes. See output below:
sh service-policy ****-POLICY DE
Status     : ACTIVE
     *.*.175.110   tcp        eq    443
      loadbalance:
        curr conns       : 0         , hit count        : 0
        dropped conns    : 0
        client pkt count : 0         , client byte count: 0
             LB action: :
                    state: UP
            hit count        : 0
            dropped conns    : 0
             LB action: :
                    state: UP
            hit count        : 0
            dropped conns    : 0
     *.*.175.110   tcp        eq    80
      loadbalance:
        dropped conns    : 0
            LB action: :
                    state: UP
            hit count        : 0
            dropped conns    : 0
netternewbie Fri, 11/01/2013 - 08:48
Actually I have changed VIP address so need to double check firewall now. Sorry.
netternewbie Fri, 11/01/2013 - 10:08
Sorry for delayed response Kanwal. We had some problems here with other things. I will try what you suggested Monday morning and get the server guys to check their things.
I will let you know how I get on. Thanks for all your help and patience. Hopefully we get it sorted Monday.
netternewbie Tue, 11/05/2013 - 08:53
Hi kanwal,
Unfortunately I am still having problems. Below is the current config. Do you see anything obvious that is wrong? At the moment the application is listening on 8443, there are certs on the two servers and there was a reverse proxy configured but this is turned off now.
cert chain-ROOT
cert ****CAcert
port 8443
interval 3
ip address *.*.*.*
inservice
ip address *.*.*.*
inservice
inservice
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
3 match virtual-address *.*.*.* tcp eq https
3 match virtual-address *.*.*.* tcp eq www
2 match http url .*
class SSLCLASS
class class-default
class class-default
Fnu Kanwaljeet Singh Tue, 11/05/2013 - 08:57
  • Cisco Employee,
Hi Netter,
Hmm..Let us do this way. If you configure a simple tcp port 8443 loadbalancing(nothing to do with ssl offloading) does it work?
So you will configure a VIP listening on port 8443 and if client comes on that VIP with dst port as 8443 the request would be sent to your server listening on 8443. If that works then we are sure that routing is fine and it is ssl configuration which is problem.
Can you test that?
Kanwal
Fnu Kanwaljeet Singh Tue, 11/05/2013 - 08:59
  • Cisco Employee,
Hi Netter,
And yes your config looks fine. Can you also get a pcap from client while testing the existing configuration?
Can you also send me output of show conn
Kanwal
