Warning message
Int f0/0 and f0/1 networks cannot communicate. reason?
Oct 30th, 2013
I have tow networks on my two router interfaces i.e on f0/0 and f0/1. I can ping from pc to the other network pc but canot ping the other network switch nor both switches can ping eachother. I cannot understand why. plz help.
John Blakley Wed, 10/30/2013 - 12:53
  • Purple, 4500 points or more
Do you have any acls or firewalls in between the two networks?
HTH,
John
*** Please rate all useful posts ***
JohnTylerPearce Wed, 10/30/2013 - 13:37
  • Silver, 250 points or more
Can you post the configuration of both interfaces? Also if these are windows machines, is it possibe to turn the firewall off and test again?
harris_732 Fri, 11/01/2013 - 04:03
No, I don't have any acls or firewalls in between the two networks.
prajithtr_2 Thu, 10/31/2013 - 02:17
Does the manage IPs of switches adverise properly in the router and could you check the default gateway in the switches configured properly..
Kindly post the configurations
harris_732 Fri, 11/01/2013 - 04:18
Yes I have checked and the default gateway was not configured on the switches. now its working . Thanks Alot to everybody here who responded to my query.
Miguel Angel Bustos Thu, 10/31/2013 - 03:39
The IP's are in the same network? The gateway's are of both switches are configure correctly?
harris_732 Fri, 11/01/2013 - 04:19
Yes the gateway was not configured, now its working. Thanks alot
Related Content
