Unable to run tcl script via crontab(buffer error)
Oct 31st, 2013
Hi All
I am correcrtly executing the script below from my linux server. However, it seems that once I try to run it via crontab (correct permisions have been set etc) I get the following error:
can't read "expect_out(buffer)": no such variable
    while executing
"set output $expect_out(buffer)"
    ("foreach" body line 6)
    invoked from within
"foreach cmd $commands {
        send "$cmd\r"
        expect -re $prompt
        #remove zeros from the cmd filename
        regsub -all {[ \r\t\n]+} ..."
    ("foreach" body line 20)
    invoked from within
"foreach device $device_list {
# Set each device's log file to be the name of the device...
    set file_name $device
# we initiate the SSH connection
Crontab is:
0 4 * * *          /usr/bin/expect  /<path of the script>/<script name>.exp
Script below:
#!/usr/bin/expect
# Here, we specify all our commands in a list, that we will issue one
# by one at a later time.
set commands [list "show ip route summary" "show interfaces" "show arp" "show ip ospf neighbor"  "show ip eigrp neighbor" "show cdp neighbors"]
# Set the date.
set date [timestamp -format %C%y%m%d]
# This variable is for a file called switches.txt that has the hostname/IP
# of all of the routers you are collecting information from.tepad
set device_list [read [open "/<path>/switches.txt"]]
# Specify the username and password, as well as what we expect the routers'
# prompt to be.
set pass "*******"
#set prompt "#"
set prompt {([#>]) ?$}
# This command tells expect not to echo the output to the console.
exp_log_user 0
#log_user 1
# We loop through each device in our list, one by one...
    eval spawn ssh $device -l ********
    match_max [expr 32 * 1024]
#If we see a message asking about the device's host key, accept it.
    interact -o -nobuffer -re "assword: $" return
    send "$pass\r"
# Loop through each command that we specified earlier.
    expect -re $prompt
    send "term len 0\r"
    expect -re $prompt
        send "$cmd\r"
        expect -re $prompt
        regsub -all {[ \r\t\n]+} $cmd "" correct_cmd
        set fd [open /<path>/$file_name-$date-$correct_cmd.txt w]
        puts $fd $output
        close $fd
    expect -re $prompt
    send "exit\r"
    exp_close -i $spawn_id
    exp_wait
Not sure why this is the case. Anyone can recommend a solution?
Pantelis
Overall Rating: 4.2 (5 ratings)
Joe Clarke Sat, 11/02/2013 - 10:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Could it be that you need to fully-qualified path to ssh?  I'd think it would fail earlier, though.  You may want to re-enable user logging and exp_internal to see what expect is doing when run from within cron.
pantelis1 Sun, 11/03/2013 - 04:31
hI Joseph
I have already done that and the problem is below:
can't read "expect_out(buffer)": no such variable as per my initial post
Pantelis
Joe Clarke Sun, 11/03/2013 - 10:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
But if you enable more debugging, you will see the what is being sent/received to/from the device.  If this variable isn't being set, there is something with the match criteria.  What is the full output when you have log_user and exp_internal enabled?
pantelis1 Mon, 11/04/2013 - 00:14
Hi Joseph
Even after enabling log_user 1 I am still not able to get any errors (to be honest I am not getting the buffer error either this time ). The relevant config is :
I have also edited the crontab to output the file as per below:
Crontab is:
0 4 * * *          /usr/bin/expect  //.tcl > //output.txt
#exp_log_user 0
log_user 1
I have also tried
exp_log_user
log_user 1
in both cases the the script runs via crontab it does nothing.The output on the relevant log file is :
"spawn ssh x.x.x.x.x -l ****"
Joe Clarke Mon, 11/04/2013 - 12:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Can you try fully-qualifying the ssh path.  For example:
spawn /usr/bin/ssh x.x.x.x -l ****
pantelis1 Tue, 11/05/2013 - 04:39
It performs exactly the same but this time produces :
Joe Clarke Tue, 11/05/2013 - 12:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Sorry then.  I'm out of ideas.  I'm not seeing the debug I'd expect.  Maybe there's a problem with your cron implementation.  Could also be an environment variable you need to set or not set...
Maher Abdelshkour Wed, 12/18/2013 - 07:25
  • Silver, 250 points or more
Hello Pantelis,
You need to declare the whole of expect_out global rather than just one element.
Thank you!
pantelis1 Thu, 12/19/2013 - 03:44
Hi Maher
Could you please elaborate on this?
Pantelis
Maher Abdelshkour Thu, 12/19/2013 - 06:17
Pantelis,
Use the curly braces to avoid substitution.
1. interacting with a program on your local machine:
#!/usr/bin/expect -d
spawn "/bin/bash"
send "term len 0\r"
expect -re eof
puts $expect_out(buffer)
2. interacting with a remote program over ssh:
!/usr/bin/expect -d
spawn ssh [email protected]
set prompt ":|#|\\\$"
interact -o -nobuffer -re $prompt return
send "mypassword\r"
send $cmd
send "exit\r"
expect eof
Hope this helps
Regards!
Related Content
