Deleting Group object in ASA
Answered Question
Oct 31st, 2013
Hi Everyone,
Fw1  has say object group subnet1
Fw1#sh run object-group id  subnet1
object-group network subnet1
group-object test
then i did
Fw1#sh run object-group id test
object-group network test
network-object 10.0.0.0 255.0.0.0
network-object 172.16.0.0 255.240.0.0
network-object 192.168.0.0 255.255.0.0
Fw2#sh run object-group id subnet1
Also Fw2 has
network-object object 10.0.0.0
network-object object 172.16.0.0
network-object object 192.168.0.0
My question is if i add the  config below   to Fw2
group-object test
and then delete the below config from fw2
Will it make any difference in running config of fw2?
will it cause any outage?
Mahesh
Correct Answer by Jouni Forss about 3 years 9 months ago
So if I understood you correctly then you have
  • FW1 with an "object-group" configured that contains inside it another "object-group"
  • FW2 with an "object-group" with 3 "network-object" statements which you want to remove and replace with a similiar "object-group" as in FW1
If this is true then I guess this is a similiar thing that you asked before.
You would have to have this already on FW2 or configure this on the FW2
You would then add this "object-group" under the other "object-group"
group-object test
And while under the "object-group network subnet1" configuration space you would remove the "network-object" configuration lines
no network-object 10.0.0.0 255.0.0.0
no network-object 192.168.0.0 255.255.0.0
no network-object 172.16.0.0 255.240.0.0
With that order you should have the same subnets/networks under the "object-group" all the time. You SHOULD NOT remove the "subnet1" object though if its in use in an ACL I think the ASA wont even let you remove it.
Again if these are used only for interface ACLs then I imagine these changes wouldnt cause a problem. If they would be used for NAT then I am not so sure.
I personally am not a big fan of grouping objects under other objects. In the long run the configurations become hard to read.
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Thu, 10/31/2013 - 10:01
group-object test
- Jouni
mahesh18 Thu, 10/31/2013 - 11:50
Hi Jouni,
Yes you understood correctly.
Its always good to get advice from you.
Best regards
MAhesh
