Warning message
Jaime Valencia Fri, 11/01/2013 - 18:43
  • Cisco Employee,
  • Hall of Fame,
    2011
No, you can use the export utility from the ciscounitytool.com site, but you would need to know what parameter youre looking for to sort the file.
Ronald Smith Sat, 11/02/2013 - 12:23
Thank you, but are you refering to  the COBRAS Export tool?  The information that I need to gather from the Custom Mailbox Quota table is the following, Warning quota, Send quota and Send/Receive Quota values that are provisioned in the system.
Example: Warning quota 25
               Send Quota    45
               Send/Receive Quota 55
Rob Huffman Sat, 11/02/2013 - 18:19
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ronald,
You'll want to check out this Tool from the great suite of Unity/Unity Connection Tools
Connection User Data Dump (CUDD) Tool
The   Connection User Data Dump (CUDD) is a Windows-based remote database   administration tool available on the Cisco Unity Tools website. CUDD   allows you to export specific information about users to a file that  can  be viewed or imported into another application, such as a database   utility or Microsoft Excel. When the data is exported, the tool   automatically creates a header row that lists the data type found in   each column of the output, for ease of import into other programs.
The tool is available from the "Superb" Unity Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Ronald Smith Sat, 11/02/2013 - 21:13
Rob,
I did try that tool, but the problem is the values don't match to what's provisioned in the system, for example, I have the following values configured,
Warning quota 45
Send Quota  50
Send/Received Quota 55
After generated the report, I compared the values, but they don't match.
