Warning message
I want to add some 2600 series AP's to our existing deploment of 1131 AP's
Leo Laohoo Fri, 11/01/2013 - 20:13
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It's the same thing.  The same radiating patterns.  The same PoE power draw.
If your current 1130 setup has good roaming, then all you need is to upgrade your controller firmware and you should be able to swap out the 1130 for the 2600.
Scott Fella Sat, 11/02/2013 - 16:17
  • Hall of Fame,
    2017 Wireless
Leo is right... Just to add though, 802.11n clients tend to stick to 802.11n AP's and could produce roaming issues due to them being sticky. They will eventually roam when they loose connection to an 802.11n AP. You might think about disabling 802.11n until you have fully migrated all the access points in a building or roaming area.
